Replace Old Deck Posts - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 01:00 PM   #1
replace old deck posts
I just bought a house with the deck attached to it, the fence around it is too low, I will have to replace the posts, but they are attached with both nails and screws, how do I remove them without damaging the joists?
jack z is offline   Reply With Quote
Old 05-12-2010, 01:59 PM   #2
There is a tool designed for pulling nails, but if you are going to replace the posts, cut them off immediately above and below the joists and then split whats left of the post with a hammer and chisel!
How to replace posts before concrete is poured rosco Building & Construction 31 05-07-2010 02:54 AM
built a new cedar deck used galvanized instead of screws should i replace all nails? abbyaudi Carpentry 8 04-19-2010 10:57 AM
Reinforcing 6x6 Pressure Treated Deck Posts jweiner Building & Construction 24 02-01-2010 08:20 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 07:03 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
