-   -   Replace hardwood stair treads (http://www.diychatroom.com/f14/replace-hardwood-stair-treads-93285/)
acerunner 01-23-2011 10:11 PM
I have really old hardwood flooring strips on the threads, and painted risers. The hardwood is oak, according to contractor, I can't tell the difference between wood species personally.
I wanted them to be replaced since I am also replacing the hardwood flooring around the house, so they would match. But he says it cannot be done, and that he would just sand and refinish.
It doesn't make any sense to me why you would not be able to replace hardwood on stairs. Can anyone explain how it would be done?
Thanks.
Just Bill 01-24-2011 07:23 AM
There is not such thing as "can't be done", given enough time/money. But I would say, that from an economical standpoint, it is a lot easier to refinish the stairs. When finished, they will look like new.
JoeLena 01-24-2011 08:25 AM
If you can't tell the difference between species, what does it matter?:)
But treads are a little thicker than usual flooring, but any woodworking or cabinet shop can get you the wood, plane it to the correct thickness, glue it up if needed and put a bull nose on the front.
As stated, just depends on the time and investment you want to make.
Ron6519 01-24-2011 08:44 AM
Originally Posted by acerunner (Post 576554)
I have really old hardwood flooring strips on the threads, and painted risers. .
What does this mean? Did someone apply flooring to the tops of the treads?
If you have closed stringers, replacing the treads makes no economic sense as the staircase would probably need to be removed to get the treads out.
Try posting pictures if you don't know what you have.
Ron
acerunner 01-24-2011 03:37 PM
let me clarify what i meant. Given a plank of wood, I don't know what to look for to identify the species of wood. However, put two species of wood side by side and I can tell they are different. I just wouldn't know what they are, oak, pine, maple, cherry, etc. I suppose its just a matter of being exposed to enough different woods to learn to identify it.
I don't have a photo on hand, but here's one i found on google that's similar to what i have.
http://www.flickr.com/photos/heritagestairs/3903239094/
Ron6519 01-24-2011 04:03 PM
It only shows one side of the staircase. The side shown has closed stringers. If you have that set up on both sides, you won't be replacing the treads without a lot of effort.
Ron
masterofall 01-24-2011 04:44 PM
I believe your concept of flooring strips is a laminated tread and your flooring contractor realizes he will have to take the stairs appart to change the treads. In other words they are structural and probably in a housed stringer. It is not flooring attached to a tread underneath.
Sand them and they should torn out beautiful
acerunner 01-24-2011 04:49 PM
Ron
yeah, its same on both sides.
I'm not 100% clear on the construction of stairs. I assumed the skirt on the side is just trim, so can be pulled off to replace hardwood. And that stringers are behind that, inside the wall.
Is that incorrect? Is the skirt part of the stringers?
Ron6519 01-24-2011 05:11 PM
In a closed system, the stringers are dadoed out about 3/8" into the wood. The treads are installed from behind the stringers by sliding them into the dadoes on each side. After that, shims are driven under the treads and behind the risers to lock them in place. The shims are usually glued and nailed(1 per shim) in place.
You can remove the ceiling in the staircase under the one you're working on and disassemble the treads and risers that way.
Like I said, a lot of work.
Ron
Millertyme 01-24-2011 06:52 PM
I would say what it all boils down to is that it would be faster and cheaper to sand down the old treads. If done right there will be no difference between them and new ones...except the cost. However, if there are problems with the old ones, such as deep gouges, structural problems and cracks or if they are the wrong species, then you might want to replace them. Hard to tell without a actual pic. Of course replacing them can be done. Either your carpenter doesn't think he can do it or he just doest think it is worth it.
acerunner 01-24-2011 07:31 PM
ok i'm convinced. i'll do the sanding.
But for education sake. Are the finished flooring planks nailed into the thread substrate (plywood?) before sliding into the dadoes? Such that the finished material is IN the stringers thus making it impossible to remove? That's what I gather from Ron's explanation.
this is sort of how I thought it would work:
http://www.youtube.com/watch?v=FYiiAnui_hI
Ron6519 01-24-2011 08:40 PM
There are just stair treads. There is no substrate with an applied flooring.
Ron
Millertyme 01-24-2011 09:08 PM
your stair may not be built with housed stringers. Some stairs are built with 2x10 stringers cut out like what you would see on a deck. Then the trim skirts are put in place on the outside walls. Next the risers are put in place between the skirts and the treads are fit on top of the rough cut stringers. This is a very typical way to do it but not the best. Some stairs are prefabbed. In this case there is no rough stringers. The stringers are also your skirtboards. The treads are dadoed into the stringers and held in place with wedges. The risers are done the same way. Everything slides in from the back. when done this way the stair needs no addition support. If you look at the end of your treads where they meet the skirt and you see a space, then you do not have housed stringers.
Keith Mathewson 01-24-2011 09:14 PM
Take a look at the underside of the stair, cut a small hole in the sheetrock if necessary. You will then know what you are dealing with.
acerunner 02-21-2011 12:23 PM
3 Attachment(s)
ok, i finally got a chance to get to the underside of the stairs.
Here are the pictures.
