Repairing Termite Damage With Wood Filler In Florida - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-11-2013, 11:05 AM   #1
Rewards Points: 331
repairing termite damage with wood filler in Florida
It's the pine windowsill (almost all of it) and window frame. Is that too much to repair with wood filler? Is there a good wood filler or is it too much of a bandaid?
When I easily stuck a screwdriver in the wood, (carpenter?) ants escaped. Should I treat for the ants now or wait for the carpenter to tear the wood out and ask him to kill them? Seems to me if I wait, the ants might be exposed better and killed better? Thanks for your help.
DIherself is offline   Reply With Quote
Old 07-11-2013, 11:51 AM   #2
Rewards Points: 14,312
Got a picture?
If it was mine I'd be opening up that wall and looks for the nest and repairing all the hidden damage.
No way are they just in the window.
Old 07-11-2013, 01:42 PM   #3
Rewards Points: 331
pictures coming soon
Thanks. Should the wall be opened from the outside or the inside or does it matter? I'm in Tampa Bay FWIW.
Old 07-11-2013, 01:58 PM   #4
Without all the info hard to say.
What's on the walls inside and out?
If it's just sheetrock on the inside than that may be the easiest.
Old 07-12-2013, 07:55 AM   #5
Rewards Points: 331
the bug man cometh
The inside is real pine paneling from the 50's; the outside is asbestos siding over wood. The exterminator is coming today to treat the window.
He said with all the rain we've had here in Tampa Bay lately, the ants have been coming in where there is termite damage, and he's going to treat from the outside and the inside.
I guess I have to wait till it stops raining before the wall gets torn out and repaired anyway, yes? How many days do you think it would take the carpenter to tear and repair?
Thanks so much for any other info.
Old 07-12-2013, 08:11 AM   #6
I would not mess with the outside.
No one's even seen a picture of this window, or is on site to look at it, and even if someone was there, there not going to have X-ray vision. So there's no telling how long or how expensive it will be until it's opened up.
If they just drill a hole and shoot some chemical in, it may or may not take care of the problem.
Old 07-12-2013, 10:53 AM   #7
Rewards Points: 331
understood
That's very clear, what I needed to hear. Thank youl
Old 07-12-2013, 11:01 AM   #8
A little side story.
For many years my mother complained to my dad that she could hear crunching noises when she was in the bathroom at there summer camp inside the sliding door.
Well if you knew my mother, she was a little out there so no one paid much attention.
Once in a while you would see an ant and someone would just kill it.
Many years after my mother passed we were doing some remodeling and found enough carpenter ants to fill 5 gal buckets.
We removed the old hollow core door and found the whole inside solid full of ants.
Old 07-13-2013, 10:15 AM   #9
Rewards Points: 331
bug man identified ants as Argentine ants...
...and said they were eating the fungus that grows on termite-damaged wood. I always agreed with you that I should tear the wall out, but I, at least, wanted to get the bug man out here immediately to take care of 1 out of 2 issues.
He sprayed all the windowsills, floorboards, and outside around the house and said they would be crawling the walls if I didn't exterminate. (He's been doing it for 42 years here in Florida, same location.)
If I sent you a picture, it would just show a window with termite damage around the frame and lines of cracks in the windowsill. But you're right; I need to tear it out. I just hope the spraying will buy me some time.
It's a good thing your mother kept nagging your father to listen to her.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Repairing wood around stucco kerschk Remodeling 6 07-31-2012 09:59 PM
Wood filler for outdoor use spaceman spif Carpentry 1 08-25-2011 03:40 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Repairing the wood for painting bofusmosby Painting 4 06-16-2007 11:55 PM
