Repairing Stairs - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-20-2009, 11:22 AM   #1
Electrician
ctsmiths's Avatar
Rewards Points: 150
Repairing Stairs
I am in a 3 floor condo built in 1984. The stairways are super cheap, they come loose all the time. I repaired the first to second floor ones because I could get to the underside of the stair case. The second to third floor stairs have sheet rock covering the underside. So my question is, is there a way to repair from the top or am I looking at a sheet rock job?
thanks
ctsmiths is offline   Reply With Quote
Old 01-20-2009, 02:50 PM   #2
Drywall contractor
Rewards Points: 1,070
Sheetrock repair if you go from the bottom, or carpet repair if you go from the top. You could try running screws in through the carpet to help stabilize the treads. Don't know if that will help your specific problem....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-20-2009, 03:54 PM   #3
Electrician
ctsmiths's Avatar
Rewards Points: 150
Im replacing the carpet any way, so top not a problem but what about if the shims are loose, any super secret way of doing this without removing sheet rock? Maybe some type of bracket?
Old 01-20-2009, 03:57 PM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
I see your from Conn., so most likely the stairs are built within closed carriages, Correct. or are that cut stringers. If your repairing them often I'm thinking they are closed stringers ( boxed stairs) with glue wedges for the treads and risers. the majority of the times when I repaired these type of stairs the side stringers seem to spread apart and the glue wedges loosen up and fall out. If this is your scenario, then you will need to pull the side stringers tight to the risers and treads, this could be done with installing shims between the studs and the stringers then reinstalling the glue wedges, banging them tight to bring the threads up tight in there mortise. and the same to the riser. then installing four screws into the back of the riser into the thread. another way wood be to install some threaded rod every three feet under the stairs pulling the stringers tight to the threads. Ill try to post a picture of the type of stairs I'm talking about. Your best bet is to remove the sheet rock and fix them for good. Good lugk and I hope this helps. BOB
Old 01-20-2009, 07:19 PM   #5
Electrician
ctsmiths's Avatar
Rewards Points: 150
It does thanks, Guess I know what I ll be doing with my vacation.
Old 01-20-2009, 08:03 PM   #6
buletbob's Avatar
Good choice! And Good luck, BOB
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 09:24 PM
Removing wall under stairs Lankston Building & Construction 3 06-10-2008 07:50 AM
Concrete stairs jmat1980 Building & Construction 2 04-18-2008 11:45 PM
Prefab or custom stairs? brokie General DIY Discussions 1 01-21-2008 07:11 PM
