Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-08-2009, 11:39 AM   #1
Default Repairing Split in Wood Door?
Hi Guys,
What is the best way to repair a split in a wood door? Our front door has a split from the bottom of the door all the way up to the bottom of the window(about 12 inches from the bottom). The split goes completely through the door where you can see light coming through the door.
I thought about just putting very strong wood glue in the split and clamping it down but I worry that would eventually resplit. Is there a better way to do this?
diyintexas is offline   Reply With Quote
Old 10-08-2009, 12:02 PM   #2
That sounds like the way to go, glue and clamp.
Check to see that both the top and bottom of the door has been sealed against moisture. I would repaint the whole door again to insure it is sealed.
Ron
Old 10-09-2009, 02:12 PM   #3
Gluing and clamping would be the best alternative if it will hold. You might try these epoxy wood restoration products. They are a bit pricey but I like working with them. This assumes the door is to be painted.
http://www.abatron.com/cms/buildinga...intenance.html
sdsester is offline   Reply With Quote
Old 10-09-2009, 10:52 PM   #4
texas,
I've had success using a shop vacuum to suck the glue all the way through the split. Lay your bead of glue on one side of the door and use the vacuum to suck it out on the other side. Then clamp and hope for the best.
Best of luck with the project, rredogg
rredogg is offline   Reply With Quote
Old 10-11-2009, 03:00 AM   #5
Household Handyman
Depends on how far the split is from either door edge. IMO--putting glue into the crack/split and clamping it until it dries is just buying time until it splits again. Your first problem is to determine why the door split: either the wood has dried out or has been wetter than it should have been over some period of time. I like to use screws to pull these doors back together, along with a good exterior wood glue in the split. The chances of a door splitting after installation of screws is nill. IF the split is near the middle of the door there is a way to use an extended drill bit to get into the door that far, from one edge, to put wood screws in. Good Luck, David
More On This Topic
So now I'm pretty much doing the Henna design and I'm going to embellish it with some glitter glue and jewels. So what I'm going to do is pick out part of the design that would be a natural area to add the little glue. I think that the tips of the... Read More »
Hi! This is John. Now we are going to be talking about seasoning of firewood. What that primarily means is firewood that has been dried out. Typically it takes about six months to a year depending on your climate once you have chopped a piece of wood... Read More »
Alright, and now we're going to continue with decorating. We've got all our functional space. We've got our pen holder and we have our mail holder and our little note holder here, so we're going to continue decorating and personalizing it, getting into... Read More »
If you have children who are musically inclined, and want to make an orchestra where every child can play together (or by themselves), you can do it at very little cost. Perhaps you already have a rain stick. Why not add sand blocks as well? They can be... Read More »
Repairing a split in a bentwood chair gives renewed life to a beautiful style of furniture. Most splits occur on the outside of the curve of the bent wood. This happens because the wood fibers that were stretched during the bending process actually tear... Read More »
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 05:19 PM
repairing (front door) jam settinhooks Carpentry 4 04-29-2009 11:47 PM
Wood Door Repair dwtow Carpentry 6 11-28-2007 09:33 PM
Swapping exterior door perpetual98 Remodeling 3 11-27-2007 07:55 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
