Repairing (not Replacing) Dry Rot Porch - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 12:01 AM   #1
Repairing (not replacing) Dry Rot Porch
The ends of some of my porch planks/boards are rotting, not the boards in their entirety. Some day I will likely rebuild the porch but for the time being would like to fix them so it doesn't look so horrible. Looking for a clever way to do this without having to rip them out. Here's a shot:
jpascone is offline   Reply With Quote
Old 05-04-2013, 02:04 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 296
I do not think there is any way, clever or not.
But what do I know, I am just a dumb painter.
The Following User Says Thank You to chrisn For This Useful Post:
jagans (05-05-2013)
Old 05-04-2013, 02:56 AM   #3
Rewards Points: 626
well you can try the Rot doctor? he has a web site called rotdoc.
But I agree that maybe way to late to save that.
Nailbags is offline   Reply With Quote
Old 05-04-2013, 06:41 AM   #4
kwikfishron's Avatar
Rewards Points: 348
You could cut those boards back like 5 “, add a nailer and then a new board turned the other direction.
kwikfishron is online now   Reply With Quote
Old 05-04-2013, 08:23 AM   #5
Rewards Points: 236
Originally Posted by kwikfishron View Post
You could cut those boards back like 5 , add a nailer and then a new board turned the other direction.
BINGO ! but i would use a larger board, at least a 10"x.
and you also have to be sure of what is under what you see.
Fix'n it is offline   Reply With Quote
Old 05-05-2013, 04:30 PM   #6
Too Short? Cut it Again!
I like this idea. You might need a couple same size as what you have rather than a wide one that will warp. And you have the posts to navigate.
Hope we are not seeing the tip of an iceberg and that you have something to sister a nailer to under there. Be careful to match the height or you will create one nasty trip hazzard.
Old 05-05-2013, 04:44 PM   #7
Rewards Points: 348
Agreed, I'd want to get underneath and take a peak before cutting anything.
Should have mentioned that the first time.
Old 05-05-2013, 08:07 PM   #8
Roofmaster
Rewards Points: 2,172
It will take longer, and end up looking like crap to try to save what you have. Sometimes you just have to bite the bullet and rip it out. You have reached that point in my opinion. You are probably going to find some rot in the substructure as you go along, so you will be able to fix that too. How does air get under the deck? Or does it?
The Following User Says Thank You to jagans For This Useful Post:
user1007 (05-06-2013)
Old 05-05-2013, 08:59 PM   #9
Haverhill Trade 1965
If you are going to do anything you should do it right. The joists must run right to left in the picture, one board at a time, find the nails at least one joist in, and pull them out of one board. If you have an oscillating saw cut the board off at line square in the center of the joist. Remove the end of the board. If not use a sharp 1/2" to 3/4" chisel flat side towards the house and (1) drive it in a quarter of an inch or so across the line. (2) From the outside at about a 45 degree angle chisel in toward the first cut removing a triangle shaped piece. Repeat steps 1 and 2 until you cut through to the joist. Remove the outside piece. Stagger the joist cuts 2 or 3 joists so no 2 cuts are adjacent. If the joists are OK, I would soak the framing underneath with bleach to kill any rot fungus, let it dry and put a thick coat of paint, (oil base if you have it), on to seal them, (under side of new boards too). Replace the pieces you took out while the paint is still wet. They should last a few years
Duckweather is offline   Reply With Quote
Replacing Deck Boards on Screened in Porch kendoit Building & Construction 12 01-24-2017 01:34 PM
Front Porch Extension km5tq Building & Construction 7 02-16-2012 03:33 PM
Replacing porch columns MPH Building & Construction 5 04-01-2010 09:19 AM
Replacing Porch Column base, what wood to use? Shamus Building & Construction 7 05-31-2008 12:29 PM
replacing porch supports smallcrpt Building & Construction 11 07-03-2007 08:03 PM
