Repair Rotted Window Frames With Bondo? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 09:44 AM   #1
Rewards Points: 298
repair rotted window frames with Bondo?
I have several window and door frames at my house that are rotten. It's the same situation for most of them - the section about 3 inches up from the sill (or floor) is rotted from the inside out. You can push your finger in and it just crumbles away. Sometimes the paint is still there - but the wood under it crumbles. With a few - they feel a little spongey.
I had a contractor tell me that I could fix with Bondo. I told him I was worried about the moisture in there and mold. But he said that wood doesn't breed that.
So I figured I could take a grinding bit on a drill and just drill out the dryrot/rot. Then fill with Bondo and sand. Just like filling a cavity at the dentist, right?
Anyone have any thoughts here?
denemante is offline   Reply With Quote
Old 09-13-2011, 10:22 AM   #2
Experienced
Jackofall1's Avatar
Your first inclination is correct, the rot is caused by moisture, first find why you have moisture issues, you will likely have some mold farms growing as well which should be taken care of.
Once you have identified and repaired the reasons for moisture, then you can think about how to fix the framing. Cut out the old rotten wood and replace with new and repaint.
Mark
The Following 2 Users Say Thank You to Jackofall1 For This Useful Post:
oh'mike (09-14-2011), Rob1975 (09-14-2011)
Old 09-13-2011, 11:06 AM   #3
Rewards Points: 298
Thanks for the reply. You're right - I've got to figure out why it's happened. The house is 13 years old and this wood is original.
In each case, the vertical piece that rotted sits on top of a horizontal piece. And since it's the very bottom of the vertical piece that's bad - my best guess is that the caulk dried up, and over time, rain hit the sills and worked its way under the end of the vertical piece - and rotted it from the bottom up. I also think the previous owner "overlooked" it and painted over it.
I'm not one to cover up problems myself. But my main concern is with Bondo - I'd seal in the problem - and it would continue to get worse.
I think what the other contractor meant was that if I sealed it up - it would stay sealed and nothing would spread/grow within the wall.
This is all on the outside of my house, by the way.
Old 09-13-2011, 12:40 PM   #4
DIY Enthusiast
I just fixed a similar situation on 3 windows. In my case, it was the bottom corners of the window sashes that had started to rot under the paint. I used System Three Rot Fix, SculpWood and a couple wood scraps to do the repair. I'm very happy with the outcome... time will tell how it holds up over the years. Bondo may work, but I would prefer to use a product specifically designed for wood repairs (Abatron is another company with similar products)- they are a little pricey though.
Ed G is offline   Reply With Quote
Old 09-13-2011, 11:32 PM   #5
Rewards Points: 5,336
To have these go bad that soon indicates an incorrect installation of the doors and windows throughout the house. There's a good chance all or most of these are in various stages of deterioration. The ones facing the weather would be the ones prone to initial issues.
I would think all these will need to be removed and repaired or replaced.
Expect some sheathing damage and if left untreated, structural issues.
What exterior does the house have?
What make of windows?
It sounds like an issue a customer had with MI windows in a manufactured house upstate.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
kwikfishron (09-14-2011)
Old 09-14-2011, 12:05 AM   #6
Rewards Points: 298
The siding is hardiplank. Outside trim, frames and sills are wood. I've heard that neighbors have had issues with these "cheap" windows - but I don't know brand. The problem seems to be the wood is dovetailed in various places around the window - that the wood shrunk and exposed the inside - which the swelled, rotted, etc. In some cases it cracked seals and the windows fogged.
Thankfully, I have no such problems. All my windows are fine (except for this rot I speak off on a few).
Yes, my greatest fear with this issue is that if left untreated - it would cause much greater damage.
That's why I was wondering if I cored out the rot then patched if I would leave something behind inside that would continue the deterioration.
The areas are small and I know I could fix it to where you couldn't tell it was ever done. THEN - everything would be painted and sealed and watertight. I can't imagine the damage getting worse.
Yes - I might seal in a little old rot - but I know my house isn't going to fall down.
But I don't have an x-ray. The only way to tell if there was more damage inside the wall/frame would be with one - or by tearing off the siding and trim and looking. Seems that's a bit overkill...
Old 09-14-2011, 01:58 AM   #7
Not a Noob or Boob
I would never risk a cover up repair. If you can poke a finger through, there is more damage than you think. My guess is the contractor figured you were not going to pay what it would cost to do it right and wanted out of their, so he told you to fix with Bondo.
It is never "overkill" to do it right.
I am also not sure why you posted this question if you already had your mind made up. Were you looking for people to tell you it was okay to take the short cut?
Rob1975 is offline   Reply With Quote
Old 09-14-2011, 08:13 AM   #8
I tried to explain what will happen, but you seem to want to do it your way.
This is not the way to do it.
The repair will not last.
Your other windows will be involved at some point.
But this is not my house, so do whatever you want.
Ron
B. Franklin 1759
Old 09-14-2011, 08:45 AM   #9
kwikfishron's Avatar
Rewards Points: 86
Your entire thought process on how to resolve this issue is wrong. There are pros here willing to help but until you take the blinders off this thread is just a waste of time.
Post some pictures.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 09-15-2011, 10:08 AM   #10
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
denemante, I used Bondo to repair some rot on my fascia boards a few years ago and this year it started falling apart despite priming and painting over it. My rain gutter started falling off because the screws lost their bite, so now I am replacing the entire board. It may be okay for small repairs but any substantial rot you probably want to either replace the board or use one of the epoxy wood hardeners and fillers.
Here is one site for info, but there are many brands of this stuff.
www.rotdoctor.com
Oh-Fudge is offline   Reply With Quote
Window repair reimersjo Windows and Doors 1 08-03-2011 08:55 PM
Painting aluminum window frames Rustygaff Painting 4 07-21-2011 03:41 PM
How do replace rotted wood in window frame? Sherm Windows and Doors 7 07-13-2011 02:50 PM
How do I repair my window frame sherlock Carpentry 18 12-20-2006 09:54 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
