Repair Door Frame On Hinge Side. - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 11:37 AM   #1
Rewards Points: 262
Repair door frame on hinge side.
Not finding the anwers to this particular problem anywhere on the net. The bottom part of the door frame where the hinge is attached is torn right off. Can I cut and replace that part of the frame or do I need to replace the entire length of the board?
Jim F is offline   Reply With Quote
Old 08-30-2010, 09:50 AM   #2
Rewards Points: 262
Figured it out for myself. If anyone interested, it works fine to replace just the damaged section of the damaged frame member. In my case I cut 6 inches above and down to the floor. The frame nails into the jack stud anyway so it was adaquate to juse loosen up the trim pieces on the bottom, cut and remove damage, naikl on new piece and reattach trim. I didn't even need to completely remove the trim which saved me from having to realign it. Fortunately, in my case there was no shimming on the hinge side otherwise that would have to be matched also.
The Following User Says Thank You to Jim F For This Useful Post:
BigJim (08-30-2010)
Whirlpool Side By Side Not Making Ice Anymore!! handy man88 Appliances 57 07-14-2011 07:33 AM
Replacing existing exterior door and jamb oneaustin Remodeling 1 04-12-2010 06:06 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
Cathedral ceiling without sofit vent on one side ChrisO Roofing/Siding 3 01-31-2007 11:51 AM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 12:00 PM
