#1 |
repair corian
i need to resize a corian counter top where can i get supplies to do this i need to cut and bevel one edge of it and i would like the color to match
#2 |
Moderator
repair corian
Corian is normally cut with a large and powerful router (like a porter cable speedmatic) and carbide router bits. Pattern bits can be used to clean up the edges, and a bearing chamfer bit can then be used to cut the chamfer.
#3 |
repair corian
Use only carbide tipped saws and router blades. Don't use reciprocating type saws. Saw from the back side to avoid chipping. You may find router bits at big box, but I doubt it. Check a tool supplier or where solid surface material is sold. They are not inexpensive.
#4 |
repair corian
hey thanks fore the tip on cutting and beveling the corian but i also hace to add a piece for a smaller range top opening also i have to add to the thickness of one edge to be reformed any ideas on how to glue corian and re hide the seams
#5 |
repair corian
You need the adhesive for Corian in the correct color. If you have that, lots of clamps. For joining two pieces, use scrap blocks of material and hot melt glue, then clamp that ot hold the pieces. Be careful of alignment. For edge build up, just clamps. Then clean up the joint with a router, or sand working up to fine Scotchbrite pads.
| Display Modes | |
| $1440+ labor only repair on 3 yr. old Goodman unit!?! | JMK | HVAC | 23 | 05-06-2012 11:45 AM |
| Choosing a Refrigerator based on Repair Value | 1655graff | Appliances | 5 | 03-01-2011 09:49 AM |
| Repair Compounds | saggdevil | Painting | 3 | 04-25-2010 04:02 PM |
| How can you cut a piece of Corian coutner? | Sephora | Kitchen & Bath Remodeling | 3 | 05-06-2009 07:54 AM |
| Fire repair | detroitguy66 | Building & Construction | 3 | 08-20-2008 06:49 AM |
