Repair A Cedar Glulam - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-02-2009, 12:26 PM   #1
Question
Repair a cedar glulam
One of my customers has a cedar glulam in their house with quite a check in it. I was thinking about repairing it with an epoxy. Does this sound reasonable or is there a better way?
joeblowofidaho is offline   Reply With Quote
Old 06-02-2009, 09:59 PM   #2
Whatamess
What kind of load is on it and can you post pictures?
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 06-03-2009, 07:56 AM   #3
Registered User
Termite's Avatar
Cedar glulams sure aren't common, and it wouldn't have been all that wise to use one in an application that involves much load. Southern pine and fir are the industry norms in the glulam business (fir is the norm in your neck of the woods, and southern pine is the norm in the eastern half of the USA).
I can't imagine that the checking would be in more than one of the laminations unless this thing was home-made by someone that didn't use dried lumber. Can you provide a pic?
If the glulam is structurally compromised by the checking I don't think that epoxy is going to help much, at least in the lower 1/2 of the beam (the tensile portion).
Old 06-03-2009, 08:14 AM   #4
Rewards Points: 5,336
Delete
Duplicate post
Old 06-03-2009, 08:15 AM   #5
A cedar glulam sounds like a structural oxymoron. Sort of like a balsa wood glulam.
Ron
Old 06-03-2009, 01:36 PM   #6
Here are pics of the glulam.
The check does not go all the way through, it's just on the side showing and is about 10' long, maybe 3/4" wide.
The roof is rated for 150#/sf snow load, so it probably is Doug Fir. The thought was to fill it with resin and brace it up while it cures. Would lag screws to pull it up to the resin help?
Repair a cedar glulam-beam-context.jpg   Repair a cedar glulam-beam-separation-detail.jpg
Old 06-03-2009, 04:24 PM   #7
Registered User
Rewards Points: 5,514
I'd replace that. The bottom couple inches is under tension, and who knows how deep or what that separation did to the structural load rating. It's called de-laminating, not checking. Be safe, G
Old 06-04-2009, 07:51 AM   #8
Registered User
Termite's Avatar
Yup, you appear to have a pretty serious failure there. No, epoxy and bolts won't restore enough of the strength to the tensile part of that beam. Time to look into replacement, or involving a structural engineer at the least.
Old 06-06-2009, 03:10 PM   #9
Aren't these supposed to be installed in the interior of a structure?
Ron
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
cedar deck looks like crap silky Painting 16 05-02-2009 10:42 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 07:06 AM
Cedar Siding Repair jlaky2000 Carpentry 5 05-11-2008 07:29 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
