Removing Wood Stain From Playset - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-30-2016, 05:42 PM   #1
Rewards Points: 77
Removing Wood Stain from Playset
I recently stained my kids' Playset with Minwax Sedona Red, and discovered that there are some spots on plastic that I did not initially see. I have tried to use Mineral Spirits to remove these stains, worked on the vinyl slide, but not on the swing seats or handles. I am fairly certain that those are ABS plastic. I've tried Mineral Spirits, WD40, Magic Erasers + WD40.
Justins1171 is offline   Reply With Quote
Old 05-31-2016, 06:10 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,718
Re: Removing Wood Stain from Playset
Is the plastic a bit UV degraded?
Once it opens up a bit, that stuff can be pretty porous. I am not sure you are going to get it out if you aren't getting any movement with those other items.
Old 05-31-2016, 06:17 AM   #3
Rewards Points: 728
Bleach? I think hydrogen peroxide also bleaches.
Is the stain also urethane premix?
carpdad is offline   Reply With Quote
Old 05-31-2016, 09:27 AM   #4
ExpertRoofing's Avatar
Rewards Points: 14
I think bleach will tore off the colour of the affected areas.
ExpertRoofing is offline   Reply With Quote
Old 05-31-2016, 06:11 PM   #5
Rewards Points: 77
The plastic is a bit UV damaged. The stain was not a urethane premix. It's presently pouring right now, but I'll give bleach a shot tomorrow
why do i need to paint my house? homie Painting 17 07-04-2015 02:04 PM
solid color wood stain through an airless paint sprayer su casa Painting 6 06-08-2015 07:06 AM
Removing poly and stain canoes Painting 22 03-05-2012 07:04 PM
Removing stain from deck machouinard Painting 20 09-08-2011 09:12 PM
Stain is too dark on wood floor -- Can it be lightened? proofer Painting 8 09-06-2009 09:28 AM
