Removing A Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 07:44 PM   #1
removing a wall
I want to remove 110 inches of wall. The wall now is just the same as a framed wall. Two 2x4s on the header and footer then studs 16 inch centers. Can I remove the 6 studs and install a engineered beam supported with a floor jack on each ends. It is a cement floor.
clubweb is offline   Reply With Quote
Old 10-06-2010, 06:05 AM   #2
Not enough info. You may be able to remove it with no additional support or it may need support. Need to know what is above. Probably best to have someone qualified have a look-see.
Old 10-06-2010, 07:21 AM   #3
Civil Engineer
Rewards Points: 4,790
it is usually possible to remove a load bearing wall and replace it with an appropriately sized header supported on properly designed posts. This is pretty routine work, however it does require a design by a qualified individual (may require a professional engineer, check with your local code enforcement official), temporary support of the ceiling during the operation, and proper installation of the elements. You will most likely need a building permit, so you should start the process by discussing the rules and regulations that apply to your particular location with the code official.
Daniel Holzman is online now   Reply With Quote
removing wall, making arc, need to determine dimensions ilyaz Kitchen & Bath Remodeling 1 03-03-2010 06:30 PM
Remodeling/ Removing a wall/ Load bearing?? hybridhatchc1 Building & Construction 3 01-22-2010 11:14 AM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Removing load bearing wall jjbarnes911 Remodeling 6 01-08-2009 09:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
