Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-19-2009, 05:58 PM   #1
Default Removing stair case
Wanted to post this on the contractorstalk website but here is just as good I suppose.
I want to remove a stair case in a house and close the hole in between the floors so they both act as a seperate entity.
Anybody know how big of a job this is? and what exactly would be done to close the gap to allow normal use above ensuring its safety in the meantime?
Can any contractors on here advice on what the job entales?
I won't be DIYing this job for obvious reasons, but wanting to understand what the job entales and how it would be achieved..
yankep is offline   Reply With Quote
Old 10-19-2009, 06:14 PM   #2
Residential Remodeler
How are you going to be accessing the 2nd level after the stairs are removed?
It is a fairly straightforward job.
The stairs are cut out and removed. The opening in the floor/ceiling is framed in using dimensional lumber that matches the existing framing. Joist hangers are a must.
Then it is simply installing some drywall, subfloor and finishes.
CookeCarpentry is offline   Reply With Quote
Old 10-20-2009, 01:27 AM   #3
Just be sure to run it by your local Building Department first, to make sure. As you are changing from a single family residence to a two family, there are things you need to address. Zoning, sewer, light and ventilation, headroom, basement egress, bedroom egress, heating and cooling, fire-code drywall on the ceiling below, hallway width, smoke detectors, utility room separation, and fire protection come to mind. Check with them so you don't have to tear it out and rebuild everything later. Notify your Homeowners Insurance Agent of the changes, too.
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 10-20-2009, 03:13 AM   #4
It is in fact being change from one place of residence to two and upstairs will be accessible via externally built stairs accompanied by a new entrace.
The supply of electricity and water however will not be changed at the moment (in terms of supply that is), so I believe I would need a HMO license. Although I am finding out exactly what needs doing for self-contained flats now to take in to consideration.
Thanks for the reply to both of you, was very helpful.
I have considered bedroom egress when looking in to windows and doors ect. (Although expect a thread soon asking for advice on the safest and most effective way on cutting through the wooden frame for widening windoes ).
I have also considered how I will provide their own heating. A new boiler will be installed (which obviously in itself has its own regulations) so supply their hot water and heating, but connected to a single mains for the time being.
I will be needed some new drywall for the ceiling however, I will need to also find some way on controlling to level of noise between floors (I believe some acousic drywall, insulation between the floors may help here, any tips ...)
With regards to headroom however, that shouldn't change should it? :S
Old 10-20-2009, 11:55 PM   #5
"With regards to headroom however, that shouldn't change should it? :S" ------ that pertains to habitable space. As a second family will live in the basement, it is up to the local B.D. as to call for basement headroom or standard (upstairs) headroom. They could be different requirements.
A lot of answers can be found on your City's Building Department web site, as most are now posting everything they can to help you understand their requirements without phoning in.
Be safe, Gary
More On This Topic
Hi! My name is Larry Hammel, singer, songwriter, engineer and producer of Deep Waves Studio here in New York City and on behalf of Expert Village, I would like to welcome you to how to produce a recording artist. We all love the sound of tape. It's the... Read More »
Icy stairs are more than just an annoyance. They can be a dangerous hazard that can lead to serious injuries. Each year, thousands of injuries, including broken bones, are reported by people that have slipped on icy outdoor stairs. You'll want to find... Read More »
How to Choose Drywall
How to Choose Drywall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about choosing drywall. There are a lot of different choices when you choose drywall. The drywall that I have chosen for this project is 5/8’s of an inch thick... Read More »
How Much Drywall Do I Need?
How Much Drywall Do I Need? by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about calculating materials for drywall. Each sheet of drywall is 4 feet, so I am going to go ahead and measure the length of my wall. The measurement of my wall is 23... Read More »
Right now I started a project. When I first started it had all the ceiling, the whole ceiling was taking down. So I had to put tracks so I can put the new ceiling up. I'm trying to sound proof it so when they record down here. I build the booth so when... Read More »
what's the safest way to install a chandelier over a stair case? diy'er on LI Electrical 18 08-01-2009 05:15 PM
Removing subfloor nickdu Flooring 3 07-28-2009 10:34 AM
some questions on stair case skirt boarding (how to measure, cut, materials) dwichman Carpentry 2 04-06-2009 07:40 PM
Lighting for stair risers jweiner Electrical 2 04-06-2009 07:18 AM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 07:54 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
