-   -   Removing Sheetrock ceiling (http://www.diychatroom.com/f14/removing-sheetrock-ceiling-172073/)
Mstrlucky74 02-16-2013 08:11 AM
265 Attachment(s)
We are going to be removing Sheetrock in our living room and put up new. Above the ceiling is our unfinished attic. We have insulation betwwen the rafters above this ceiling and are hoping it stays put when the ceiling is removed. What is the best way to remove a Sheetrock ceiling? Start going crazy with a hammer ? :whistling2:. Thanks a lot
joecaption 02-16-2013 08:14 AM
Why not just go over the old ceiling with new drywall, A whole lot less mess.
123pugsy 02-16-2013 08:23 AM
X2.
I see no reason to remove the old ceiling either.
ecocco1469 02-16-2013 08:24 AM
I just replaced my entire ceiling also. Best way is to go in attic n move insulation out of way n vacuum this one person can push old rock down n get nice big peices down at a time. If u pull down from bottom u will get small peices n make huge mess with insulation. N sheet rock will be more of a pain to take down. Try putting up 5/8 rock instead of 1/2 in. U can rent drywall jack for 30 at Home Depot for day
joecaption 02-16-2013 08:30 AM
A drywall lift is the way to go, good point.
Once I bought one I'll never go back to the bad old days of tying to balance it on my head standing on a step ladder and yelling at each other all day.
It can make it a one man job.
Mstrlucky74 02-16-2013 08:40 AM
265 Attachment(s)
Never thought about putting the new over the old. Seems much easier but seems to be a 50/50 split here. Any negatives to putting new over old? Thanks a lot
joecaption 02-16-2013 08:52 AM
I see someone suggesting how to remove it because that's what you asked about, but there not suggesting not to go over.
I've done it both ways. The only time I remove the old is in really old houses with undersized sagging joist.
That way I can sister them to make the whole ceiling flat and level again.
Mstrlucky74 02-16-2013 09:10 AM
265 Attachment(s)
Thanks Joe. How to you find the joists to nail the new sheetrock to?
joecaption 02-16-2013 09:33 AM
Stud finder, go up in the attic and just drill a small hole on each side of the rafter, look for divits or nail pops in the ceiling.
If you go in the attic and check to see if the joist are evenly spaced, once you find one it's just a matter of marking off the rest.
I like to use blue tape on the wall to mark out where the joist are.
Just going to have to use longer screws when installing it.
BigJim 02-16-2013 10:09 AM
Another vote for installing over existing sheet rock. If you have never taken any down, you have missed all the mess, and especially a face full of junk in your face. Try this in an old house where they burned coal.:eek::whistling2:
joecaption 02-16-2013 10:12 AM
Your also going to have to deal with the fact the ceiling was installed first and the walls second. So you would have to dig out all the old rock that's stuck in there when the ceiling comes down.
joecaption 02-16-2013 10:18 AM
The worst ceiling I ever took down was in an old movie theater.
Were 50 ft. above the floor, old stamped steel ceiling panels, then 4" of old news paper laying flat, 6" of celluose, 2" of old pigen poop.
BigJim 02-16-2013 10:26 AM
Ewwwww :eek:I thought the coal dust, rat and mouse droppings was bad enough.
bbo 02-16-2013 10:30 AM
are you sure all the poop was old?
I'd have to get fully suited up for that ... ummmm ... crappy job.:whistling2:
joecaption 02-16-2013 10:59 AM
Mask, suits, duct tape on ankles and wrist.
We were doing this in a building with no heat in the middle of winter when it was well below zero.
