Removing A Screw With No Head - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 08:49 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Removing a screw with no head
I am trying to remove the glass screen from my fireplace so that I can clean the glass. It is a gas fireplace.
There are screws that I need to remove but the threads on them have stripped and one of them is missing the head completely.
How do I remove these screws?
I think they may also be melted in there.
Thanks for you help.
yummy mummy is offline   Reply With Quote
Old 10-11-2011, 10:25 AM   #2
Maryland
Stripped, broken head and melted. Doesn't sound very promising.
If the screw is large enough, you can try a screw extractor set. Otherwise, you may have to drill it out, re-tap the hole and install a larger screw. Post a photo or two if you can.
Pittsville is offline   Reply With Quote
Old 10-11-2011, 02:05 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Machine threads or wood?
Old 10-11-2011, 04:10 PM   #4
Bud, I doubt that the doors for a fire place would be made of wood!
The Following User Says Thank You to Wildie For This Useful Post:
bob22 (10-12-2011)
Old 10-11-2011, 04:18 PM   #5
If some of the screws have their heads broken off, perhaps someone has already tried to remove them and broke the heads off.
I think that you may be correct, that they are 'melted' in there.
The glass in fireplace doors is rarely removed. If its possible at all, it may be best to clean the glass with it left in place.
The only other option would be to drill out the screws and re-tap the holes.
Old 10-11-2011, 04:21 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No kidding!!! Do ya think?
That doesn't mean there aren't sheet metal screws that look like wood threads.
Seemed the simpler way to ask the question.
Yummy understands.
Old 10-11-2011, 10:20 PM   #7
Rewards Points: 5,336
I doubt they are melted, more likely frozen. You can spray them with PB blaster and wait a few days to unscrew them. Or you can use a screw extractor to back them out. Either way, I'd use the Blaster.
It works on exhaust systems on 40 year old cars like a charm.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Bud Cline (10-11-2011)
Old 10-12-2011, 03:44 PM   #8
Thanks everyone for all your suggestions.
This is my brother-in-laws fireplace. I will ask that he send me a photo.
He wants to clean the inside of the glass as it looks really foggy.
Old 10-12-2011, 07:07 PM   #9
Be careful with the pb blaster... It works great but is flammable!
jfrotten is offline   Reply With Quote
Old 10-12-2011, 07:46 PM   #10
If you have no head, I take this to mean you have no eyes to read this... so I think all the advice on here is in vain.
oldhouseguy is offline   Reply With Quote
Old 10-12-2011, 10:03 PM   #11
He told me that he used a torque screwdriver (whatever that is....lol)
Is there a particular screw remover kit that he would be able to use?
Here is a photo if that helps.
Old 10-13-2011, 08:00 AM   #12
If it has a grippable head, you can try a vise grip. If not, use a screw extractor. You drill a hole in the center of the screw and insert the extractor and unscrew it from the inside. You need to drill the hole with the correct soze bit associated with the extractor size.. It has to be to the correct depth and not an "enlarged" hole you get with wobbling the bit.
You can buy an extractor set for a variety of screw sizes. It should run under $20.00
Ron
B. Franklin 1759
Old 10-13-2011, 12:25 PM   #13
Ron, I must be terribly unlucky, as I inveribly break the extractor off in the screw and the I'm in real deep trouble.
The extractor is made of hardened steel that is impossible to re-drill.
I would only us an extractor, when I have given up on removing the screw and don't care anymore, whether I hack it up, or not!
Old 10-13-2011, 12:51 PM   #14
Thanks everyone.
Thank you very much Ron. I will tell him to use a screw extractor and drill a pilot hole first. I think that should do it.
Old 10-13-2011, 01:27 PM   #15
47_47's Avatar
Rewards Points: 76
Carefully center punch the screw and use a left handed drill bit.
47_47 is online now   Reply With Quote
removing stainless steel screw joetab24 General DIY Discussions 16 08-13-2011 05:33 PM
Robertson tip stuck in screw djgrant General DIY Discussions 4 07-05-2011 04:18 PM
Oversize Screw Guide tonynace Carpentry 7 04-16-2011 08:37 PM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 12:59 PM
Removing a headless screw - How to? Roxanne Akimbo Carpentry 6 03-12-2009 08:56 PM
