Removing Saw Dust From Cabinet Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 05:48 PM   #1
jep
Rewards Points: 33
Removing saw dust from cabinet doors
I have a bunch of Spanish cedar plywood kitchen cabinet doors and drawer fronts that have very fine sawdust on them from the cabinet shop. THey're unfinished right now. Before I put the finish on I need to get them cleaned off. I was thinking of starting by vacuuming them and then going to tack cloth. Suggestions?
jep is offline   Reply With Quote
Old 08-25-2012, 05:56 PM   #2
DIY staff
Rewards Points: 7,174
I would use an air hose and then a tack rag---but a vacuum with a soft brush will do the same thing---
I avoid vacuums because a bare hose will leave rub marks and I can never find a brush nozzle ---
jep (08-25-2012)
Old 08-25-2012, 06:03 PM   #3
Old School
cabinetman's Avatar
You could vacuum, and then blow it off with an air hose (if you have a compressor). I wouldn't use an ordinary tack cloth, as it can leave a residue. If a tack cloth is needed use a dry one like this.
cabinetman is offline   Reply With Quote
The Following 2 Users Say Thank You to cabinetman For This Useful Post:
jep (08-25-2012), oh'mike (08-25-2012)
Old 08-25-2012, 07:04 PM   #4
Old School
cabinetman's Avatar
I should have added a qualifier that if using an air hose, to do it some place other than where any finishing will take place. Generally, in a small shop with confined space, the air will get stirred up and keep debris airborne for quite a while. When all that krap settles, it stays light and loose and can get dispersed easily.
So, do stuff like that as far from the working area as possible.
The Following User Says Thank You to cabinetman For This Useful Post:
jep (08-25-2012)
Old 08-25-2012, 09:21 PM   #5
jep
Rewards Points: 33
Maybe it would be worth it to rent a compressor for a day. I could blow them off outdoors and then take them directly into the basement where they'll be finished.
Old 08-26-2012, 11:26 AM   #6
In a little over my head
Rewards Points: 706
A shop vac with a brush is a good start. I've had good luck with the micro-fiber tack cloths referenced above. Works good. Wash 'em out and reuse.
ratherbefishing is offline   Reply With Quote
Old 08-26-2012, 11:30 AM   #7
GBrackins's Avatar
Rewards Points: 2,108
would be good justification for buying one ........ gotta get your tools and accessories to be able to perform projects around the home
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-27-2012, 10:30 PM   #8
Bombastic Idiot
notmrjohn's Avatar
Use an inline water filter with that compressor. A cheap 4" soft bristled paint brush comes in handy. Homemade tack cloth of cheese cloth dipped in diluted what ever your using for finish, really wrung out, and folded into pad leaves a residue compatible with your finish , the residue can collect more dust tho. I've sometimes used a barely water moistened cloth as tack cloth IF I've already raised the grain with damp cloth in earlier sanding process.
notmrjohn is offline   Reply With Quote
hinges on flush-face cabinet doors vs. old door hinges denemante Kitchen & Bath Remodeling 1 08-05-2012 06:47 AM
Kitchen Cabinet Doors llckll Appliances 0 05-13-2010 08:27 PM
Installing Cabinet Doors PapaFerg Kitchen & Bath Remodeling 2 05-12-2010 08:33 AM
Removing a kitchen cabinet, I give up... cold-fish Remodeling 4 07-19-2009 08:15 PM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 06:26 PM
