Removing A Nail - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 05:57 PM   #1
Removing a nail
Ok, no laughing, this sounds simple but I have a huge thick, screw I cannot remove from a stud. Not sure how to get it out. I have used a screwdriver, plyers, drill and no luck. Any suggestions?
D'brat is offline   Reply With Quote
Old 04-05-2012, 06:08 PM   #2
Civil Engineer
Rewards Points: 4,694
If the head is still sticking out, you might use an impact screwdriver (I bought one at Sears a long time ago). This is a screwdriver meant to be hammered on. You hit it, it twists. The blow from the hammer drives the head into the screw, and keeps it there during the blow. Works well if the head still has enough left to bite on.
Old 04-05-2012, 06:26 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Sawzall with a metal blade.Cut it right to the wood.
sublime2 is offline   Reply With Quote
Old 04-05-2012, 07:47 PM   #4
Rewards Points: 282
screws have poor sheer strength....hit it laterally with a hammer and sheer it off, thats what i do.
jcrack_corn is offline   Reply With Quote
The Following 3 Users Say Thank You to jcrack_corn For This Useful Post:
mae-ling (04-07-2012), princelake (04-06-2012), woodworkbykirk (04-05-2012)
Old 04-05-2012, 07:53 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Yes,but would it sheer at the stud or further out is the question.
Old 04-05-2012, 07:57 PM   #6
Rewards Points: 1,578
Pair of Vice Grips?
bob22 is offline   Reply With Quote
Old 04-05-2012, 08:50 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
they typically snap off just outside the wood. just beat the remainder into the stud
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 04-05-2012, 10:54 PM   #8
In a little over my head
Rewards Points: 706
Vise-grips, sawzall, oscillating tool, hack saw, hammer, whatever you've got. If it ends up "not flush", take it flush with a file.
ratherbefishing is offline   Reply With Quote
Old 04-06-2012, 08:22 AM   #9
Rewards Points: 506
Put some muscle into it.
jlmran is offline   Reply With Quote
Old 04-06-2012, 01:18 PM   #10
Drywall contractor
Rewards Points: 1,070
Get a bigger hammer....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-06-2012, 10:20 PM   #11
Registered User
Rewards Points: 5,492
Or just drill 3 holes tight around it with a 1/4" bit to loosen it's holding power for easy removal.
Gary
Old 04-07-2012, 07:02 AM   #12
Rewards Points: 2,212
Is it a Lag bolt? then breaking it probably isn't going to work, driling 3 holes is a neat trick.
mae-ling is offline   Reply With Quote
Old 04-07-2012, 11:55 AM   #13
To avoid compromising the stud, you could just cut it off with a hacksaw. If its in a tight spot put a few turns of duct tape around a loose hack saw blade or gol it in a vise grip.
Evstarr is offline   Reply With Quote
Old 04-07-2012, 09:10 PM   #14
Thanks all, I wound up sawing the sucker off! All gone!! Thanks to all I really appreciate it!!!
The Following User Says Thank You to D'brat For This Useful Post:
mae-ling (04-08-2012)
Removing wood framed window bonded with liquid nail MNYShum Windows and Doors 1 03-19-2011 04:49 PM
Framing nail gun is blowing holes in my fence TheMac13 Building & Construction 4 06-28-2010 05:31 PM
Nail gun shock injuries dswan388 Roofing/Siding 11 11-24-2008 06:34 PM
Nail gun shock injuries dswan388 Tools 5 11-02-2008 08:46 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 08:10 PM
