Removing Kitchen Soffit - Load Bearing?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 04:54 PM   #1
Removing Kitchen Soffit - load bearing??
I'm in the processing of removing the soffit in my Kitchen that is over my cabinets. After removing most of the drywall, I saw that it was framed was 2' x 8' that expands the length of the kitchen. A friend who is helping thought that they might be load bearing.
My house is a 1960's tri-level with a gable roof. The kitchen is on the main floor, no second floor over it. There main floor is 25' x 22' with a load bearing wall that divides the kitchen(11' x 13'),dining room(11' X 9') and living room (14' x 22).
The soffit extends about 30" from the wall and housed recessed lights and L shape. The walls that the soffit is on: One wall backup against the upper and lower, and the second wall against the exteior (load bearing wall). As i stated, the framing consists of 2 x 8 on both walls.
I will appreciate any help or advice. Thanks
adrien2 is offline   Reply With Quote
Old 09-18-2011, 05:10 PM   #2
DIY staff
Rewards Points: 7,174
I doubt if it's load bearing----Post a picture or give us a more detailed description of the ceiling itself.
Old 09-18-2011, 05:29 PM   #3
here is couple more pic. The last pic, we have already remove the soffit and found the the ceiling joists was framed with 2 x 4.
Removing Kitchen Soffit - load bearing??-proj2-002.jpg   Removing Kitchen Soffit - load bearing??-proj2-001.jpg
Old 09-19-2011, 09:15 AM   #4
Too Old
My opinion is that it is not load bearing and when they built the house instead of peicing the soffit with 2x4 they used joist material. I have done that alot using joists or TJI', it makes building a soffit much easier.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 09-25-2011, 06:29 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
based on that picture its not load bearing, its simply allowing for one peice of wood to act as backing for the plaster. since its so close to the wall the ceiling joists and rafters are bearing on the wall.
if the 2x8 were bearing it would be tripled and bearing on posts on the end
woodworkbykirk is offline   Reply With Quote
Load Bearing Wall Weakened chronojosh Building & Construction 4 04-04-2011 10:08 PM
removing wall that soffit was attached to Lizybizy Building & Construction 3 05-27-2010 03:48 PM
removing load-bearing walls and moving the kitchen WannaReno Remodeling 2 04-02-2010 05:05 PM
Remodeling/ Removing a wall/ Load bearing?? hybridhatchc1 Building & Construction 3 01-22-2010 11:14 AM
How to determine if it's a load bearing wall? tripower Building & Construction 8 12-30-2008 09:42 PM
