Removing Interior Wall In Mobile Home - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 05:55 PM   #1
I was removing an interior wall to make my living room bigger in a 2000 Fleetwood 16 x 70. After I removed the sheet rock from 1 side i discovered 3 2 x 4's stacked on top of each other with 3 large bolts going thru them and into the floor. Does anyone know what this is? I suspect it is where the trailer is attached to the frame. Can I remove this or maybe leave just this section of the wall and work around it? It is in a corner and I could build a small closet there. Thanks for any advice.
hillbillymike is offline   Reply With Quote
Old 11-26-2010, 06:46 PM   #2
the Musigician
DangerMouse's Avatar
I agree with you there..... leave them alone.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
hillbillymike (11-26-2010)
Old 11-26-2010, 07:29 PM   #3
Framing Contractor
No one here can possibly answer that question. Is there a name of the company who made it somewhere? If so, you have to call them.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
Old 11-26-2010, 09:17 PM   #4
Rewards Points: 274
The company is Fleetwood. I doubt they would be much help in homeowner modifications. Possibly this is a frame attachment. They probably stacked them 3 high so they could attach the wall onto the top. You may not need a 3-high stack to maintain the integrity. Look underneath to see if the bolts attach to the frame. Interior walls in a single-wide are never load-bearing, only the outer walls are.
Jim F is online now   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
Old 11-26-2010, 10:32 PM   #5
If I understand what you are saying I should be alright removing the wall as long as I leave the frame attachment in place. I ca hide the attachment by building a small closet or such around it. If I have misunderstood please reply.Thanks a lot.
Old 11-27-2010, 06:35 PM   #6
You'd probably void any warranty, if there is one, on the trailer. It does sound like it attaches the trailer to the frame but I wonder if you could replace the 2x4s with a singles steel U channel. You'd have to check how much thread there is on the other end of the bolts or be prepared to replace the bolts with similar ones. Might want to check with an engineer as the trailer manufacturer won't advise you.
mrgins is offline   Reply With Quote
Old 11-27-2010, 06:37 PM   #7
They may not be vertically load bearing, but they may be necessary for shear loads
Old 11-27-2010, 09:24 PM   #8
Thanks to everyone. i think I will just replace the drywall and leave the wall in place. A few extra feet of living room space is not worth the risk. Thanks again.
running electric under mobile home brianbrianj Electrical 8 10-26-2014 03:16 PM
Replacing Mobile Home Package AC Unit jack roscoe HVAC 3 05-24-2010 03:13 PM
mobile home wicket1 Building & Construction 3 06-07-2009 11:46 AM
deck for a mobile home rln17 Building & Construction 2 09-09-2008 05:51 PM
Mobile home electric. RobertS Electrical 7 02-27-2008 01:25 PM
