Removing Interior Living Room Walls - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 07:36 AM   #1
Removing interior living room walls
The walls of our living room are being removed. The walls look like grainey cement. House is about 80+ years old. I have been told that there will be a lot of powdery dust when the walls are banged down. Should we leave house while work is done? One person in household has asthma, allergies, etc.
CLINKER is offline   Reply With Quote
Old 02-22-2009, 07:56 AM   #2
That should be done by experts. There is likely asbestos in that stuff, and that requires very special handling and isloating the area.
Old 02-22-2009, 08:04 AM   #3
thanks JUST BILL
Thanks! I didn't even think about asbestos!
Old 02-22-2009, 08:23 AM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
Here are a few things that we perform when it comes to demolition in a home.
shut off your heating/air cond. system.if its supplied by duck work.
then take plastic ( i use 6 mil) and tape all the registers in the demo area to the walls. including the returns.
cover all doorways that are leading away from the demo area with plastic and tape, make sure the plastic folds onto the floor and is taped. this way the unaffected areas will be dust free and less clean up. It will get dusty so try to keep the other parts of the house dust free. BOB
Old 02-22-2009, 01:54 PM   #5
yes if they have asthma. and make sure the wall are not load bearing if they are and for some miracle the house stays perfectly erect then at some point in the near future it will cause some part of the house to colapse
todo66 is offline   Reply With Quote
Laundry Room Dimension Question jonathan03 Appliances 1 01-17-2009 11:08 AM
Cold Room mikelbeck HVAC 14 01-16-2009 09:21 PM
Interior walls of hot tub room MontanaDIY Building & Construction 2 01-13-2009 12:40 AM
Renovation a Block Walled Room, Above Grade Douger_F Building & Construction 4 01-06-2009 12:27 PM
