Removing Hardwoods Around Cabinets Without Taking Out The Kitchen Counter - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-04-2013, 12:42 PM   #1
removing hardwoods around cabinets without taking out the kitchen counter
dOES ANYONE HAVE AN IDEA ON HOW TO REMOVE HARDWOODS FLUSH WITH THE KITCHEN COUNTER WITHOUT REMOVING THE CABINETS? An exceptional tool that will work?
adrooker is offline   Reply With Quote
Old 08-04-2013, 01:03 PM   #2
Still Decompressing
Rewards Points: 273
I was at Harbor Freight a few days ago and saw this.
http://www.harborfreight.com/3-3-8-e...saw-94626.html
I have know idea how well it works, but for $70, it might be worth a try.
I am currently installing new hard wood floors and cabinets. This is exactly why I don't want to run the hardwood under the cabinets. I know I wont ever be replacing these floors again, but it bugs be to create a problem for someone else.
caveeagle is offline   Reply With Quote
Old 08-04-2013, 01:30 PM   #3
When you say HARDWOODS, do you mean trim, flooring .... or what? Are there more than one type of wood?
RoyalAcresRod is offline   Reply With Quote
Old 08-04-2013, 01:48 PM   #4
Rewards Points: 13,456
A Toe Kick Saw is the tool to use. I'd also pick up an Oscillating saw while I was there to cut all the way into the inside corners.
Old 08-04-2013, 02:14 PM   #5
Still Decompressing
Rewards Points: 273
A lot of people slam Harbor Freight for low quality. Fair enough, If you are a professional and use these tools on a regular basis, you would probably be better served buying higher end equip. For those of us that need specialty tools for a 1-time job, I either rent, or go to HF.
Last year, I put down 1,400 sqft of 20" Terazo tile. I got the 10" wet saw from HF for ~$300 and it worked like a champ! We did the job over 3 weekends, so renting would have been a pain, and cost just as much.
Don't forget to look for online coupons. 20% off is pretty standard there!!
Old 08-04-2013, 08:26 PM   #6
Rewards Points: 236
i have that saw. it works very well.
same goes for their Oscillating saw
Fix'n it is offline   Reply With Quote
What color to paint kitchen cabinets? kimberland30 Interior Decorating 20 11-28-2015 03:33 PM
Are Kitchen Cabinets Secure richard7994 General DIY Discussions 6 11-06-2011 06:21 PM
Refacing kitchen cabinets without any veneer? loft_lover Carpentry 1 11-18-2010 06:23 AM
installing used kitchen cabinets xcuter Kitchen & Bath Remodeling 1 07-19-2010 01:39 PM
removing wall tiles for new cabinets measure thrice Tiling, ceramics, marble 1 02-03-2009 07:03 AM
