Removing Glue From Studs - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 08:34 PM   #1
removing glue from studs
I'm helping to renovate a house that had some damage after a fire. Problem is, it is a prefab home and the drywall was glued to the studs. A lot of the drywall was pulled away from the studs. The old glue,along with some of the drywall, is still on the studs and will have to be removed before new drywall can be installed. Is the only solution scraping or can it be gotten off some other way? Taking forever to do it this way. If anybody has done this before and knows an easier way it would be appreciated. Thanks.
CramerH is offline   Reply With Quote
Old 10-19-2011, 09:22 PM   #2
kwikfishron's Avatar
Rewards Points: 1,024
Welcome to the forum CramerH.
I’d just run a Sawzall down the face of the studs and clean them right up.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
CramerH (10-20-2011)
Old 10-20-2011, 11:34 AM   #3
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
You could use a belt sander with coarse grit, or a power hand planer if you can get your hands on one.
Oh-Fudge is offline   Reply With Quote
The Following User Says Thank You to Oh-Fudge For This Useful Post:
To Glue or Not To Glue denvermatt Carpentry 9 08-22-2011 09:21 PM
Removing old carpet glue to lay laminate Dynamic Duo Flooring 3 07-05-2011 03:24 PM
How to repair rotted joists and studs? Snav Building & Construction 5 02-24-2010 10:35 PM
Help with straightening studs before drywalling genEus Carpentry 3 08-29-2008 02:12 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
