#1 |
removing glass with blinds built in from one set of doors and installing them on a different set of doors.
The sizes of the original door match match perfectly but their arrangements require me to just use the glass with blinds built in.
I've removed the inside molding from the new doors with the built in blinds and the screws but can't get it to budge from there. Do I have to remove the outside molding to get this unit out of the door? If so how do I do that? |
#2 |
Super Moderator
What brand of door?
New members: Adding your location to your profile helps in many ways.--M-- |
#3 | |
removing glass with blinds built in from one set of doors and installing them on a different set of doors.Quote:
Ron |
#4 |
A door a day is all I ask
Hi there,
I'm with Ron... There is probably a very sticky double sided weatherproof tape holding that exterior moulding in place. Try working at it with a clean putty knife. Try both the stiff and flexible types and see which one works the best for you.
Richard The Door Guy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
Window and Door installer
Once you removed the inside molding, you can spray the glass around the molding with a window cleaner, I prefer a foaming one so it doesn't run down the glass to quickly. Once you've done that you can run a putty knife between the glass and the molding to cut the double sided tape that is there. Push the top of the glass out and grab it on the other side, once you get the top out you should just be able to lift it out of the opening.
If instead of double sided tape, silicon or a putty was used, it's still possible to use this method, but will take a little more elbow grease. You may have to be firm, it's almost certainly tempered glass so you shouldn't have a problem breaking the glass. If you want to make double sure it's tempered you can look for the small tempered insignia etched into the glass in one of the corners, but it's SOP and code to make all door glass tempered so shouldn't be a concern at all. I have seen crazy things though, so better to be safe then sorry! Sometimes the seal between the panes can get a little tacky if you are in a high heat area and this can stick to the frame as well, you can sometimes cut this with a razor knife from the inside where you already removed the molding. Good luck! Last edited by Jkslate; 05-21-2011 at 04:55 PM. |
| Display Modes | |
| Thanks to my wife, installing a set of French Doors | BJLower | Remodeling | 4 | 04-04-2010 09:07 PM |
| Installing closet doors into un-true opening - Need ideas | McCool | Carpentry | 8 | 08-12-2009 02:37 PM |
| Help installing bifold doors | MT Stringer | Carpentry | 5 | 11-05-2008 11:24 PM |
| Installing laminate around doors??!! | RonR | Flooring | 8 | 01-05-2008 08:38 AM |
