Removing A Functional Door Knob With No Screws? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-20-2007, 11:41 AM   #1
Rewards Points: 264
Removing a functional door knob with no screws?
I feel like a total idiot staring at this knob all day, but I cannot figure it out!
It is on an interior hollow door, the knob is functional and does not have capability of being locked. So I want to put on a knob that locks, but I cannot for the life of me get the old one off! There are no screws that hold the two sides together, there is no set screw on the collar behind the knob that might be holding it on, and the knob does not screw on. I'm lost, any help would be appreciated!
moneymgmt is offline   Reply With Quote
Old 08-20-2007, 12:47 PM   #2
Custom Cabinet Maker
Money, take a deep breath, Yes there are screws. If you look closely at the plates on the door there will be a small slot or a little spring tab. If slot, small screwdriver into slot push detent and handle pops off, plate comes off and wallah da screws.. handle same same.
Jack
skymaster is offline   Reply With Quote
Old 11-09-2008, 05:23 AM   #3
decorative door knobs with no visible screws
How do I rmove the door knobs from an internal door. the door knobs rotate but will not come off.
mdavie22 is offline   Reply With Quote
Old 11-09-2008, 05:53 AM   #4
the Musigician
DangerMouse's Avatar
The first step in removing the old knob is to remove the knob and cover plate. If you see screws, then take them out. If not, then look for a metal tab on the shaft of the door knob. Pushing in on this tab with a flat head screwdriver and pulling on the knob should remove the knob. Then look for a separate tab holding the cover plate on, pushing this in as well and gently prying the cover plate from the door should also result in its removal. Once the inside knob and cover plate have been removed there should be a couple screws holding the other side in. Simply remove those screws and pull the other side off. If you have the combined setup, once the outside screws are removed you can remove both knobs by simply pulling them out.
DM
Old 11-16-2008, 12:29 PM   #5
Removing a functional door knob with no screws.
The door knob assembly problem has been solved. Firstly by holding the outer plate of the inner door knob and unscrewing in an anti-clockwise direction. This removes the plate together with its captive knob. The inner face plate is now exposed which has two screws which travel through the door and into the outer plate of the remaining door knob. Removal of the screws frees the other knob from the door.
Old 05-05-2011, 12:17 AM   #6
If the knob has no bolt heads showing and it's a locking door with a key, you need the key in the hole and then that will allow you to be able to push in that small pin you see on the knob shaft. The key is the key to soling this problem.
Woody420 is offline   Reply With Quote
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 12:43 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
