Removing Crown Moulding ?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 06:09 PM   #1
Rewards Points: 874
We are going to install new sheet rock ceilings and was wondering whether the existing crown moulding can be removed without getting damaged or will we have to buy and install new CM. Thanks a lot
Mstrlucky74 is offline   Reply With Quote
Old 02-15-2013, 06:20 PM   #2
Framing Contractor
Rewards Points: 118
It can usually be carefully removed and reused. Takes a lot more time, but if money is tight, it will save you from buying new. Slide an old drywall knife behind first, then get a pry bar in under that. Pull the nails out through the back of the molding to minimize the wood tear out on the front. Look to see the correct order for removal, as the coped ends fit over the others.
sixeightten is offline   Reply With Quote
Old 02-15-2013, 06:29 PM   #3
Rewards Points: 13,712
Cut along the paint lines top and bottom first to cut down on the sheetrock repairs.
Old 02-15-2013, 06:51 PM   #4
Rewards Points: 874
Thanks so much guys. Is there a place to donate here. I feel obligated
Old 02-15-2013, 06:54 PM   #5
P/M me and I'll give you a secret address you can send it to.
Old 02-15-2013, 07:04 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
depending on the type of material used it may require being a little more delicate with it.. some mdf crown is very soft which increases the chance of it flaking or chipping very easy. when you go to remove the nails in it use a set of small vice grips or pliers and pull them out from the back so the face of the crown doesnt get damaged
woodworkbykirk is online now   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
BigJim (02-15-2013), Mstrlucky74 (02-16-2013)
Old 02-15-2013, 07:17 PM   #7
Framing Contractor
Rewards Points: 118
Just make sure the material is not like this one. Removal and reinstall was not an option.
The Following User Says Thank You to sixeightten For This Useful Post:
Old 02-16-2013, 04:10 AM   #8
Rewards Points: 150
What no coped top plates???
kaschmid3 is offline   Reply With Quote
Old 02-16-2013, 06:08 AM   #9
DIY staff
Rewards Points: 7,174
I find that a 5 in one Painters tool is very useful----
Cut the caulking with a utility knife----then tap the painters tool between the drywall and trim--
When you locate a nail--place the painters tool onto the nail--hit with a hammer--and it will bend and pull the nail right out of the back of the trim----
Works like a charm --nails gone---trim loose and safe to remove---
Old 02-16-2013, 06:39 AM   #10
Rewards Points: 874
Thanks got everything but just not clear on the what exactly to do when I locate the nail....
Old 02-16-2013, 06:56 AM   #11
DIY staff
Pry the trim down just a bit---slide the tool under the trim until you encounter a nail----
Then ,with the tool in between the drywall and the trim,set the tool onto the nail---hit it with a hammer--the blade will bend the nail and pull it through the back of the trim---
Nail will still be in the drywall--and your trim will be loose---
Try it----this is a very safe way to remove trim undamaged---
Old 02-16-2013, 06:58 AM   #12
DIY staff
like this---
Crown Moulding Paint Peeling ryanb4614 Painting 6 01-23-2012 09:15 AM
How to match mis-matched crown moulding tooladdict Carpentry 5 10-13-2011 10:55 AM
Crown moulding and drywall (to tape or not to tape?) gspck Drywall & Plaster 4 11-10-2010 02:41 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 10:52 PM
Crown Moulding Question lda130 Carpentry 2 11-21-2009 10:41 PM
