Removing Caulk? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-23-2007, 10:25 PM   #1
Removing caulk?
I want to remove and redo the caulking between the backsplash and wall in the kitchen...We will be repainting the wall but want the caulk to look nice instead of gaudy.
Chris
ysrchris is offline   Reply With Quote
Old 07-23-2007, 11:45 PM   #2
Darylh's Avatar
I quite often run a knife flat across the backsplash and the same on the wall then peel it off.
Darylh is offline   Reply With Quote
Old 07-24-2007, 07:08 AM   #3
RippySkippy's Avatar
I use a razor blade using Darylh's technique.
RippySkippy is offline   Reply With Quote
Old 07-25-2007, 07:20 AM   #4
I understand about cutting it out with a knife or razorblade but what about clean-up of the flashing or residue that is left...I plan on running a smaller bead for a neater apperence. I guess what i'm most concerned about is ruining the texture on the wall. Even though I will repaint I don't want to retexture the wall.
Old 07-25-2007, 11:25 PM   #5
Darylh's Avatar
For Latex caulk I have used hot water and a scotch brite pad, for silicon I use thinner and a rag and then when finished I wash it with soap and water to get off any risidual thinner.
Old 03-04-2011, 01:26 AM   #6
Master of none
Silicone be gone
I've used "Silicone be gone" made by DAP. Just follow the directions. I find it is at most hardware and building supply stores I deal with.
Razors and scrubbing works ok for tile or enamelled surfaces but even there there will usually be some spots with a little left . But if you are removing silicone from fibreglass or acrylic surfaces I guarantee you'll damage it with a razor.
I have not tried acetone. The magic eraser sounds good. I will try it next time. I've been told that magic eraser has chemicals in it that may be harmful to children. So just a word of caution for anyone with chemical sensitivities!
handy andy is offline   Reply With Quote
Old 03-04-2011, 10:40 AM   #7
Rewards Points: 1,574
MSDS for Mr. Clean Original Eraser shows no chemicals in it and no issues except for if you eat it or rub it on skin or in eyes.
Link: http://www.google.com/url?sa=t&sourc...-VL3ig&cad=rja
bob22 is offline   Reply With Quote
Old 03-04-2011, 02:31 PM   #8
Rewards Points: 5,336
Depending on the caulk used and how sloppy the application was, you might not have a choice about the retexturing. Sometimes the effort to remove the caulk compromises the surface. Especially painted, textured surfaces.
Ron
Old 03-05-2011, 10:53 PM   #9
Use a plastic caulk installer tool and if that don't get it all lightly use a hairdryer to heat it up,then use a hard plastic like a credit card or plastic box cutter.
Stainless steel is offline   Reply With Quote
Removing Silicone Caulk... BillK40 Painting 39 10-28-2013 02:35 PM
Bathtub Caulk billinak Remodeling 17 05-27-2007 09:34 AM
Caulk Windows eric s General DIY Discussions 2 11-26-2006 09:45 PM
Removing Non Paintable Caulk davo420 Painting 7 08-16-2006 08:28 PM
