Remove Stain And Finish From Oak Furniture - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 10:20 PM   #1
Remove stain and finish from oak furniture
I have a armoire made from oak (ply and solid) that is finished much too dark for the rest of the pieces. What is the best way to removed the finish and stain? Can I just sand it off or do I need to use a stripper of some sort. It's a medium oak stain with some sort of polyurethane type finish....I wish to get to something closer to a natural finish...Thanks
Rohey is offline   Reply With Quote
Old 07-30-2010, 06:06 AM   #2
Strippers will get off a lot of what you want removed, sanding the rest. But the top layer on plywood is thin and won't take a lot of sanding. And oak grain is very rutty and difficult to get all the stain/finsh out. Stripper and a sodft bristle brush might be the best thing on the plywood, before lightly sanding.
Old 07-30-2010, 02:04 PM   #3
Rewards Points: 5,336
You might need to bleach the wood to lighten it up. As Bill said, the plywood pieces will sand through the veneer layer long before it gets to unstained wood. They make bleach especially for wood, but it's application and control has a learning curve. I would practice on some scrap pieces before the furniture.
Ron
Old 07-30-2010, 07:03 PM   #4
Ok bought stipper specifically labeled for stain and finish removing. I will give it a try and see if I can get enough of the stain color out without having to resort to bleach. It will be up against a wall so I can practice on the backside before trying.....Thanks for the help...Rohey
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Best stain for cedar siding pgreef Painting 17 07-08-2011 10:43 AM
Finish failure SidingHell Off Topic 5 05-20-2010 02:00 PM
How to remove paint but preserve original finish? Indyguy Painting 4 07-15-2009 01:36 PM
one step stain and finish RKH Flooring 2 05-04-2009 10:21 PM
