Remove And Replace Wall Cabinet - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 08:18 PM   #1
Rewards Points: 866
Remove and replace wall cabinet
I need to remove a wall cabinet in the ground floor service porch so that I can affect some repairs on the tile floor located on the second floor and immediately above the cabinets. I don't see how it is fastened; no nail heads or screw heads are visible. This is early 1990's Southren Cali tract home construction. The cabinet is pine. It appears to have a 1/8 " thick back and top.
Any suggestionis on how to get it out with as little damage as poosible? My cheap stud finder is getting some hits, but I wonder if it is just picking up the fasteners in the wall that the cabinet is hung on.
I don't want to even try cutting a hole through the top of the cabinet and trying to bend and twist to access what needs to be done.
I don't know if these pictures will help.
Remove and replace wall cabinet-wall-cabinet-002.jpg   Remove and replace wall cabinet-wall-cabinet-003.jpg
Klawman is offline   Reply With Quote
Old 02-20-2013, 06:04 AM   #2
Rewards Points: 150
I may be wrong but it looks to me it is a single cabinet and it should be nailed or screwed in the cleats on the back wall (and possibly in the sides maybe behind the hinges)
kaschmid3 is offline   Reply With Quote
The Following User Says Thank You to kaschmid3 For This Useful Post:
Klawman (02-20-2013)
Old 02-20-2013, 10:54 AM   #3
Rewards Points: 866
I hadn't thought of a cleat system and since the inside depth of the cabinet is only 1/8" less than the outside measurement to the rear wall, there doesn't seem to be space for any sort of cleat. I can slide a straight edge all along the thin gap betweem the sides of the cabinet and the walls on either side without hitting anything, even a nail. I will pop the molding off at the interface of the bottom of the cabinet and the rear wall and see if there is anything to see or reach with a flat strainght edge.
I imagine I will end up destroying the 1/8" cabinet back, but can live with that. It should be just a piece of plywood.
Old 02-20-2013, 11:51 AM   #4
Rewards Points: 150
Whst I meant was the cleat under the shelves is prob where the screws r
Old 02-20-2013, 12:13 PM   #5
Rewards Points: 866
That makes good sense and I thought I detected one under the paint of a shelf cleat. I will get the cheapo stud finder out and scrape some paint off to see if I can locate them. Thanks again.
Old 02-21-2013, 10:24 PM   #6
Rewards Points: 722
Failing all else, you can save the doors, maybe the face frame and rip out the rest.
carpdad is offline   Reply With Quote
Old 02-21-2013, 10:34 PM   #7
Rewards Points: 866
That is a distinct possibility. I don't care a great deal if the 1/8" back is destroyed. The cleats may survive with a bit of putty and if not they are easily replaced. This may give me an excuse for finally buying a pin gun to go with my finish nailer. (Besides I have to build a cedar chest for my daughter's B-Day).
Old 02-21-2013, 10:46 PM   #8
Rewards Points: 150
Good luck on both projects.
Old 02-21-2013, 11:47 PM   #9
Rewards Points: 866
Thanks. I will need it.
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-12-2012 11:36 PM
Remove half walls & replace with wood railing/balusters jjgoss Remodeling 3 06-29-2010 08:05 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
