-   -   remove and reinstall hardie backer (http://www.diychatroom.com/f14/remove-reinstall-hardie-backer-92437/)
montpsycho 01-15-2011 09:27 PM
I have screwed in 3 panels of hardie backer above my tub (i am going to tile a tub surround)
First intension were to blend the uneven gap between the 1/2 hardie backer board and the 5/8 wall panel with a joint compound of some sort. I feel it would be easier to remove the hardie backer panels and add shims behind them (paint sticks) we will be using kerdi as a waterproof membrane.
the screws which hold the hardie backer in are 1 1/8" long. when i add shims behind them should i replace with longer screws? how does the hardie backer board handle being unscrewed and rescrewed? how to the studs hold up behind the board?
Just Bill 01-16-2011 06:51 AM
That should not be a problem. If the screw holes don't look good, make new ones.
montpsycho 01-16-2011 09:07 AM
i'm guessing you are referring to the unscrewing and rescrewing of the hardie backer. i have decided it will be best to cut my own shims at 3/16". i plan on using longer screws, but i believe hardi backer screws only come in one length. can i use wonderboard screws? or a different screw all together?
montpsycho 01-16-2011 11:28 PM
hmm, looks like i may have lied. the current size of the screws is 1 1/4" long. when i went to the store i saw they also sell 1 5/8" hardie backer screws which i bought. i unscrewed the sheets of HB, put up shims on all the studs and rescrewed the HB back with the longer screws with no issues.
tomorrow i put up the kerdi and after that........
