Remove Part Of Load Bearing Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-24-2008, 05:34 PM   #1
Remove part of load bearing wall
I have a "pony wall" opening between the kitchen and family room that I'd like to install an arch in.. The span is about 6-7 feet..At the top of the opening, there is large header spanning the entire opening...Below this header is attached some 2x4 framing with short vertical blockers..this additional framing extends the pony wall an additional foot or so down. (I'm guessing the builder attached the framing to give the kitchen a more closed-in look). What I would like to do is to remove this additional framing to give me additional headroom for the curved arch...However, I'm concerned that this extended framing may be part of the overall support beam, which supports a floor above. What should I look for to determine if I can remove just the extended framing? I assume the wide beam above the framing is the support structure for the opening, but I'd like some expert ideas or guesses from you guys before I start removing the afore-mentioned framing.
billyg is offline   Reply With Quote
Old 02-24-2008, 06:57 PM   #2
remodeling pro
Look to see if there are full length "jack" studs under the ends of the header. This would be a continious stud that fits betwen the floor and the bottom of the header. If these are there, then the rest of the framing is exactly as you suspect, and merely there to lower the height of the opening to match others nearby. This is how most framers do it. Considering that you have the headers there, the ends of them must be supported already.
troubleseeker is offline   Reply With Quote
Old 02-24-2008, 11:20 PM   #3
Rewards Points: 150
Post a picture of the exposed framing and list all the measurements.
kgphoto is offline   Reply With Quote
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 07:12 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
