Remill Old cypress siding?
Our house is a 60s modern with cypress siding--effectively 5/4 x8" rough sawn, installed vertically.
Instead of being milled to a profile though (typically for these houses they used a shiplap profile that didn't butt together, creating strong vertical lines), the siding was installed using an under-strip, with the wide siding nailed over top.
Edit: poking around I see this style called "reverse board and batten"
What I have then are perfect channels for bugs etc, since they also didn't block the bottoms of the channels this created.
I have been thinking about reinsulating on the outside using foam board and reinstalling the siding as a single layer. This should keep my thicknesses consistent.
Anyone know of a resaw mill or someone who would be willing to deal with recycled boards (NYC/CT area)?
Or is this something I could do myself (I have an old Foley Bellsaw planer that I believe had molding accessories made for it).
This would require milling the boards to a shiplap profile like the attached pic.
Reason: add detail
