Reinforcing Wooden Beam - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 12:08 PM   #1
reinforcing wooden beam
we would like to take out a telepost in our basement.weve heard you can reinforce the wooden beam with steel plates on both sides.my question,is this possible?and if so what size of steel plate,thickness.type would we use.how far apart for bolts?what type and size bolts etc.the span is 17 ft.thanks sherry
sperley is offline   Reply With Quote
Old 03-12-2009, 12:42 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,314
I've seen an episode of Holmes on Homes where he did something like this. He used an engineer to spec it. You'll need an engineer to spec this too. Bolts and bolt spacing will be part of that.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 03-12-2009, 10:16 PM   #3
Carpenter
DecksEtc's Avatar
Do NOT do this without an engineer's recommendations.
If not done correctly, your house will fall down.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 03-16-2009, 07:21 PM   #4
Crazy, but lovable
flyboy2610's Avatar
And that could really ruin your whole day.
flyboy2610 is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Removing sag from wooden beam Stevo Building & Construction 4 07-27-2008 09:15 AM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
