Reinforcement For Work Bench Legs - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 11:36 PM   #1
Reinforcement for work bench legs
Hi,
I built this work bench where the legs are bolted to the top with two bolts for each leg.
http://www.flickr.com/photos/95980208@N08/8761535368/
http://www.flickr.com/photos/95980208@N08/8761529108/
Do I need to do anything else to insure the legs stay straight? Any other reinforcement that you can recommend?
tinsingh is offline   Reply With Quote
Old 05-21-2013, 07:58 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
I may be wrong but it appears in the first photo you only have one bolt/lag attaching the leg to the frame on the side and one in the back, I would use two. if this is a freestanding work bench I'd probably use some cross bracing across the back to provide more lateral stability, and a 2x at the bottom of the legs on the sides.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
tinsingh (05-21-2013)
Old 05-21-2013, 08:11 AM   #3
Rewards Points: 150
I agree, add a 2nd bolt from each direction. Add stretchers at the bottom. Then put a shelf in down there and it's useful storage space.
SquishyBall is offline   Reply With Quote
The Following 3 Users Say Thank You to SquishyBall For This Useful Post:
GBrackins (05-21-2013), tinsingh (05-21-2013), Willie T (05-21-2013)
Old 05-21-2013, 08:12 AM   #4
GBrackins's Avatar
shelf would be a nice addition, can be used for storage or a place for your feet when sitting down at the bench
Gary
Old 05-21-2013, 09:26 AM   #5
Old School
Willie T's Avatar
Short legs?
Willie T
Old 05-21-2013, 09:28 AM   #6
GBrackins's Avatar
no, tall stool ....
Gary
Old 05-21-2013, 09:48 AM   #7
Thanks Gary. I am a beginner wood worker.
Each leg does has 2 bolts, one on each side. Did you mean 4 bolts per leg?
What would a cross bracing and a stretcher look like?
Old 05-21-2013, 10:32 AM   #8
GBrackins's Avatar
yes, 4 bolts/lags total each leg.
take a 1x4 and attach it to the lower end of one back leg and run it across the back to the top of the other back leg, then repeat in opposite. it'll look like an X in the back. this helps with the side to side lateral stability if this is a free standing work bench. if you're attaching it to a wall you won't need it.
the only stretchers I'm familiar with are the ones we used when I worked EMS
squish will explain
Gary
Old 05-22-2013, 12:40 PM   #9
Oso954's Avatar
Rewards Points: 1,654
Stretchers are a brace between two legs of a table, chair, etc which are keeping the legs from spreading.
In the attached photo, the four 2x4's near the bottom of the legs.
Oso954 is offline   Reply With Quote
Old 05-22-2013, 02:43 PM   #10
GBrackins's Avatar
which would be perfect for a plywood shelf
Gary
tiling shower bench diy'er on LI Tiling, ceramics, marble 6 05-16-2012 06:57 PM
Building a bench at the end of a bath tub ashton44 Kitchen & Bath Remodeling 6 04-05-2012 06:05 PM
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 05:09 AM
Retiling Shower Bench - HELP Jamboy Remodeling 4 10-09-2007 10:03 AM
Retiling Shower Bench - HELP Jamboy Building & Construction 2 10-07-2007 11:56 AM
