Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-10-2012, 01:15 AM   #1
Refinishing worn old bar chair tops?
I'm thinking about trying out water based polyurethane to restore the round wood tops of some old bar stools we have. The wood is worn white in spots from people's butts and from being used as temporary little tables. Is this a good idea, or will it look bad?
darsunt is offline   Reply With Quote
Old 03-10-2012, 09:33 AM   #2
Stairguy
Just make sure to sand off all the old finish first. Start with 80 grit paper then work up to a 100 or 120 grit. Are you trying to match the finish to something else?
Millertyme is offline   Reply With Quote
Old 03-10-2012, 06:57 PM   #3
Thanks I will try that. I was thinking about doing one fine sand 220 over what was there, but maybe that's not enough.
This is my first refinish job, I'm just trying to make it look like it did before. I think they put some kind of clear coat over the wood itself. Probably varnish.
Installing chair rail over uneven sheetrock krazykarr Drywall & Plaster 10 12-20-2011 12:51 AM
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 01:42 PM
Painting/staining crown moulding and chair rail Gypsy601 Interior Decorating 8 07-05-2011 04:51 PM
Unique Chair Rail Obstacle mormegil Interior Decorating 4 06-03-2011 07:56 PM
Refinishing Oak Steps - How do I fix steps with worn corners trshafer Flooring 2 03-09-2011 11:05 PM
