Refinishing Side Tables - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-31-2009, 01:28 PM   #1
refinishing side tables
i have side tables bought from a hotel. they have these fire proof coatings on it. i want to change it birch looking to something cholate looking. donn't know how to go about it. like how to sand , stain and finish. any suggestions.
ritugosain is offline   Reply With Quote
Old 08-01-2009, 08:47 PM   #2
Rewards Points: 5,336
What is a, "fireproof coating"?
Ron
Old 08-01-2009, 10:15 PM   #3
Registered User
Termite's Avatar
There are a multitude of spray-on fireproof coatings used in furniture, carpet, wallcovering and drapery in hotels.
I'd suggest avoiding chemical stripping the piece at all costs...Really a lot of intensive work and depending on the quality of the piece of furniture you may do more harm than good.
You can try sanding but by the time you get down to bare wood you may sand right through the veneer that is likely applied to the piece to make it look nice.
I'd suggest picking an inconspicuous spot and sanding lightly with 220 grit sandpaper to rough the surface up. Then apply some dark colored Minwax polyshades, which is a colored polyurethane. More coats makes it even darker, just remember to lightly sand between coats. I say try an inconspicuous spot to ensure that you get a good bond between the poly and the existing coating.
Old 08-02-2009, 04:22 AM   #4
Old School
cabinetman's Avatar
WELCOME TO THE FORUM
You might try to find out which coating was applied. Some are waterbased and must be applied to bare wood. I would prefer to do a chemical stripping in lieu of sanding. Some strippers like Citristrip are waterbased and can be used indoors. They are prerty easy to use and much easier than sanding. MC based strippers (methylene chloride) are very toxic but could work faster than waterbased.
Once down to bare wood, you can apply the stain and finish of your choice.
cabinetman is offline   Reply With Quote
Durock installation in bath, what side goes out? smcmurrey Building & Construction 8 12-12-2010 06:48 PM
supply side of booster pump - need flex hose ericmc Plumbing 1 06-15-2009 11:14 PM
Refinishing square cut side of 2x6 T&G for flooring cowbore Flooring 1 11-24-2008 01:13 PM
Side By side refrigerator Susie Q Appliances 6 08-31-2007 03:26 PM
Cathedral ceiling without sofit vent on one side ChrisO Roofing/Siding 3 01-31-2007 10:51 AM
