Refacing Painted Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-02-2006, 04:55 PM   #1
I am refacing my latex painted plywood bathroom cabinets with a birch veneer. Do I need to strip the latex paint before adhering the veneer?
tripdls is offline   Reply With Quote
Old 11-02-2006, 08:54 PM   #2
Oldguy
Rehabber's Avatar
You will definetly want to remove the paint. I recommend you use a heat gun (don't buy a cheap one, they don't work)
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 11-03-2006, 11:10 AM   #3
I had already bought some brushable paste paint stripper, but you recommend a heat gun. Is the heat gun better? Or should I use in conjunction with the stripper?
Old 11-03-2006, 08:59 PM   #4
Oldguy
Rehabber's Avatar
On any flat surface you will WANT to use a heat gun. Once you try a chemical stripper and try a heat gun you'll understand. Do not use stripper with the heat gun.
Old 11-04-2006, 12:34 PM   #5
Yeh, I thought about how stupid that was after I asked it. I got a good heat gun I think(Wagner HT775), but it seems like a long process. This paint doesn't seem to blister and just gets rubbery and hard to scrape.
I think I've finally got the hang of this. When I get finished stripping most of the paint, I figure I need to sand it smooth. Do I have to remove all the paint before attaching the veneer with contact cement?
Last edited by tripdls; 11-04-2006 at 02:41 PM. Reason: Added notation and question.
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 10:23 PM
Cabinets over tile, or tile around cabinets??? harleysilo Remodeling 10 11-02-2012 02:25 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Can Shenandoah Cabinets from HD hold weight for book cases/home Office? Leibrook Carpentry 3 12-10-2006 06:26 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
