Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-19-2012, 07:08 AM   #1
Redoing Basement after flood
I've redone the weeping tile, put in a new sump pit and water proofed the out side walls with Blue Skin. Also put 2" of Rigid insulation on the outside walls. My question is if I'm putting up Rigid insulation on the inside walls do I still need to use a vapour barrier against the concrete. Since I already have a vapour barrier on the other side of the wall, the Blue Skin. How about if I use Bat insulation?
TBayDave is offline   Reply With Quote
Old 07-19-2012, 08:34 AM   #2
Super Moderator
Lots of debate about that vapor barrier--
I would not use one--just a bat insulation with a vapor barrier on the conditioned side of the wall--
There are several members with extensive knowledge---hopefully one will see this and offer a good explanation on insulating a basement wall---
Methods change in really cold climates--so adding your location will get the best answers
Old 07-20-2012, 07:17 AM   #3
Ok, Thanks for the info, I also added my Location to my profile. Never noticed that I could.
Old 07-20-2012, 07:21 AM   #4
Super Moderator
Canada,with its cold winters , has its own code and recommendations--
I'll duck out--there are plenty of members who know the best practice in your cold climate---Mike---
Old 07-20-2012, 09:03 AM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
For a basement, I would do neither Batt or vapor barrier. Either use XPS, with the seams tucktaped or Spray foam, after framing the walls, and doing rough ins. If doing the floor, XPS on the floor, seams tucktaped, then lay the OSB or Exterior grade ply down on top. That is just my two cents.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 07-22-2012, 08:26 AM   #6
Thank you for heads up. We recently redid floors in that area and I put down Dry Core. The water was high enough in spots to get the wafer-board wet. But in other areas was just damp. But even with a dehumidifier going we still had a hell of a time trying to get water from underneath the Dry Core. Was looking at a different idea for the floors. But not doing anything till I'm 100% sure I've got the water from getting in.
Old 07-22-2012, 08:45 AM   #7
Super Moderator
Consider ceramic tile for the floor---properly set it can take a flood without any damage.
Under tile heating is possible---
Old 07-22-2012, 06:53 PM   #8
GBrackins's Avatar
if using drywall in the basement I'd recommend using a paperless product. if normal drywall board gets wet then the mold can feed on the paper, without paper no food ...... food for thought
here are some interesting articles on basement insulation and vapor barriers, check them out and then ask any questions you may have
http://www.canadiansforproperlybuilt...ement_uot.html
http://www.buildingscience.com/docum...ng%20basements
http://www.buildingscience.com/docum...vapor-barriers
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-22-2012, 09:36 PM   #9
sounds like you were the one of about 6000 that got flooded in Tbay. i would not put vapour barrier on the concrete it will trap moisture. frame up your walls using pressure treat on the sill then put batt insulation min. of r12 keeping the insulation roughly 12" up from the sill. accoustical seal everything then put up a 6mm vapour barrier. and dricore is definitly the way to go unless your putting i tiles.
princelake is offline   Reply With Quote
Basement wasls, vapor barrier , options for what i have to work with bf514921 Building & Construction 3 07-13-2012 12:26 AM
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 07:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
