Recessed Shelves - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 12:50 PM   #1
Guidrychad's Avatar
Recessed Shelves
I'm gonna be wall mounting my 46" flat screen tv in my bedroom. Which is a really simple project. But I am thinking about making some recessed shelving underneath it or to the side of it to store my satellite receiver and DVD player. But I have never done this before. I've been reading up on how to do this and it don't seem too hard. Any suggestions and or tips that may help me out? ThanksGuys.
Guidrychad is offline   Reply With Quote
Old 04-16-2013, 12:57 PM   #2
Rewards Points: 2,516
Get some shelving brackets. Get them as plain or as fancy as you want.
hammerlane is offline   Reply With Quote
Old 04-16-2013, 01:02 PM   #3
"You can do anything"-Mom
brockmiera's Avatar
Definitely locate your studs first. Lay it all out to make sure it fits. I dont know too many dvd or cable boxes that are less than 14 1/2" wide and definitely not too many that are at most 5 1/2 deep. Can you post a picture of what you'd like to do.
When I hear recessed I think set back from the face of the wall.
brockmiera is offline   Reply With Quote
Old 04-16-2013, 01:51 PM   #4
Bill Kearney
Rewards Points: 1,174
Recessing the shelves would, of course, require there being room inside the walls to do it. And that there wasn't anything else already in there. You can certainly get a 3.5" recess into a typical stud wall if there's nothing else there already. But anything deeper would require room on the other side of the wall. If it's a closet or something then perhaps it'd work. Bear in mind you can't just cut through a stud and leave it hanging. You, generally, have to install a header across the top of the space. This to let the wall continue to carry it's load properly. This gets even more important (and more complicated) if it's a load-bearing wall. That would absolutely require a header and presumably support studs underneath.
So yeah, it's "possible". But there's a lot of things to consider, and a lot of work to handle them. Thus it might be considerably easier to find alternative storage for the stuff.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
brockmiera (04-16-2013)
Old 04-16-2013, 01:56 PM   #5
Rewards Points: 13,290
You can also build the wall out (make it thicker.)
Old 04-16-2013, 02:15 PM   #6
Guidrychad's Avatar
Thank you all for your ideas and suggestions. Reading all of them definitely has me reconsidering the whole recessed shelving idea. LOL. But I'd really love to do it to save space.
Old 04-16-2013, 02:29 PM   #7
brockmiera's Avatar
You could recess a portion of the shelf into the wall with the remainder sticking out. I mean the tv will stick away from the wall at least 6".
Snap a pic when you can and post it using the "Go Advanced" button below. Give us the dimensions of the shelves you want and a little info about the wall (exterior, interior, load bearing, stud spacing, etc) and we'd be more than happy to walk you thru it.
Old 04-16-2013, 03:05 PM   #8
Guidrychad's Avatar
You are right about the width and depths. I'd more than likely have to cut into a stud, which I'd really hate to do. I'm just an average DIY'R, far from professional. Lol. I'd probably tear my wall up if I start cutting into studs.
Old 04-16-2013, 04:55 PM   #9
brockmiera's Avatar
We all started somewhere! No worries if you dont but we're here if you want to.
Old 04-16-2013, 09:02 PM   #10
Guidrychad's Avatar
Will do man. I will probably work on that this weekend. Will snap a few pics before starting and post them for you to see. Thanks again for your help. I really appreciate it.
Brackets for small glass shelves in recessed tiled box amakarevic Building & Construction 2 03-26-2013 02:59 AM
Building Shelves for cat set Carpentry 7 02-29-2012 04:59 PM
Pantry Sliding Shelves nicksteel Carpentry 14 05-23-2011 06:07 PM
Cantilever shelves in bathroom pennshaq Remodeling 1 07-11-2010 09:26 PM
Recessed shelves that drop down through the ceiling marathonmedic Carpentry 1 12-02-2009 08:13 PM
