Reattachment Of Formica To Cabinet - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 06:11 PM   #1
Reattachment of Formica to cabinet
Happy New Year to all,
I must reattach some loose sections of Formica to cabinets. The cabinets are 20 years old or so. The gluing surface is not plywood but some sort of 'pressboard', which has the appearance of great porosity. Which adhesive type would give the best results for this operation? What kind of 'prep' is required to achieve maximum adhesion of the adhesive employed? Some of the cabinets are in a location of high moisture as in bathrooms. Thank you for any advice in this matter.
Regards,
Fish96
FISH96 is offline   Reply With Quote
Old 12-28-2011, 06:19 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Use contact adhesive. Prop the laminate upward away from the substrate. Paint some contact adhesive on both surfaces. Allow it to dry for about an hour then remove the prop and clamp the laminate down to the substrate. Use a piece of cardboard or something thin under the clamp to soften the point load. Leave the clamp overnight.
XXX
Old 12-28-2011, 06:20 PM   #3
Retired carpenter
As far as I know, contact cement is the only adhesive used for formica. I would wipe the surfaces to be glued with mineral spirits to clean them before gluing.
abracaboom is offline   Reply With Quote
Old 12-28-2011, 06:22 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Mineral Spirits is too oily, use Lacquer Thinner if you need to clean the surfaces..
XXX
Old 12-28-2011, 06:27 PM   #5
Rewards Points: 13,446
Good luck trying to get it to stick.
Partical board soaks up water like a sponge and swells up and turns to what looks like oatmeal.
custom cabinet countertop dilemma: notch it or redo? mystic_cobra Carpentry 14 05-12-2011 10:35 PM
Need help! Cabinet install gone slightly wrong eemichael83 Carpentry 14 10-26-2010 03:46 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
