Reattach Gate To Fence Post - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-17-2014, 08:25 PM   #1
Reattach gate to fence post
One of my double gates has come off the post. The work only lasted a couple years. The guy who did the work apparently used a couple nails at the top, one in the middle, and one at the bottom. It's a big gate-5feet. The other gate is still attached, but it's coming off the post. It seems kind of flimsy to use only nails for these big, heavy gates. Anyway, I'd like to use screws instead of nails. What kind should I use? Any other suggestions on what to use to make gates more sturdy would be appreciated. I've attached photos of the double gates and close ups of both gates.
Reattach gate to fence post-image-4.jpeg   Reattach gate to fence post-image-3.jpg   Reattach gate to fence post-image-2.jpg   Reattach gate to fence post-image-1.jpg
martuunis is offline   Reply With Quote
Old 07-17-2014, 09:45 PM   #2
Rewards Points: 240
Take both gates off. Rehang with LONG screws. If you go to big box or tractor supply, they will have a selection of heavy duty galvanized hinges for you to choose from. I would personally go with THREE hingeser side on a fence of that size. Ron
ront02769 is offline   Reply With Quote
Old 07-18-2014, 12:16 AM   #3
Thanks for your input Ron. I will rehang with long galvanized screws. The gates already have hinges on the front side. My pictures were showing the back side of the gates.
movement in new fence post sibs77 Carpentry 17 01-12-2014 11:48 PM
Anchoring Fence Posts With Metal Post Base? Boiler98 Building & Construction 0 07-08-2012 12:23 PM
installing a fence post...properly Millertyme Building & Construction 17 08-11-2011 09:23 PM
Broken Fence Post in patio! Tomperro Building & Construction 11 04-21-2011 03:27 PM
Privacy Fence 4x4 Post against Garage? jpearson311 Building & Construction 8 05-19-2010 02:19 PM
