Really Bad Door Frame Split And Then Some - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 02:18 AM   #1
Hey diy'ers, i got a problem with a messed up doorframe on the hinge side......
Any suggestions????
Tonedidit is offline   Reply With Quote
Old 01-21-2012, 02:41 AM   #2
Rewards Points: 2,212
How much do you want to spend? How do you want it to look?
You could cut out from about 2" below the hinge to 2" above the hinge and just up to the door stop, Glue/screw in a new piece and patch and sand and paint, also chisle out for hinge.
Or just replace the hinge side of the entire Jamb, you can buy un-machined (not hinges in it) jambs.
Or replace the entire door & frame.
mae-ling is offline   Reply With Quote
Old 01-21-2012, 02:50 AM   #3
I dont care how it looks and something cheap and easy
i dont care how it looks as long as cheap and easy as well as durable
[/list][/i]
Originally Posted by mae-ling View Post
how much do you want to spend? How do you want it to look?
You could cut out from about 2" below the hinge to 2" above the hinge and just up to the door stop, glue/screw in a new piece and patch and sand and paint, also chisle out for hinge.
Or just replace the hinge side of the entire jamb, you can buy un-machined (not hinges in it) jambs.
Old 01-21-2012, 02:57 AM   #4
Go with the first option then. Use construction adhesive to glue it in, predrill and screw through the edge into the existing jamb. Also predrill your hinge screw holes and shim between the hinge and the studs and use longer screws that go right into the stud.
Old 01-23-2012, 06:53 PM   #5
Rewards Points: 83
The third (free) option is to relocate that hinge above or below the split. This is not the right way to do it, but it wont cost anything, if you own a chisel and hammer.
rubberhead is offline   Reply With Quote
Old 01-23-2012, 09:00 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,326
it will also look like crap, as you will have to mortise the door again.. which both the jamb and door will now need to be patched otherwise.
go with option one.. go onto youtube and type in "dutchman Patch" if you have a trim router it will really speed things up. also using some bondo will fill any bad gaps
woodworkbykirk is online now   Reply With Quote
Old 01-24-2012, 12:26 AM   #7
Rewards Points: 83
see post #3
I totally agree with that being said. Someone who is asking how to fix this likely doesn't own a trim router though.
The Following User Says Thank You to rubberhead For This Useful Post:
kwikfishron (01-24-2012)
Old 01-24-2012, 12:43 AM   #8
Can do it was hand tools.
Old 01-24-2012, 05:41 PM   #9
Retired carpenter
Pry the crack open a bit with a screwdriver, glue both sides with a thin brush the best you can, clamp, fill the holes, slap some paint on it.
abracaboom is offline   Reply With Quote
Old 01-24-2012, 08:09 PM   #10
it can be done with hand tools yes, a hammer and a sharp 1 1/4 chisel works best
as for the glue and clamping thing.. that wont last very long to be honest. where its old wood the joint is 90% certain to fail where it has to handle the stress of the door hanging off it
Old 01-25-2012, 12:33 AM   #11
Retired carpenter
How long do you think a Dutchman will last with a door hanging on it?
(In both cases, the hinge screws would have to dig into the frame beyond the jamb.)
Old 01-25-2012, 12:42 AM   #12
Rewards Points: 14,276
I must be missing something. It looks like someone has tryed putting screws in without predrill and has split that wood all over the place.
What's up with all the small holes that are also spilt out above the hindge mortis.
Looks like a remove and replace job to me.
Old 01-25-2012, 01:06 AM   #13
Retired carpenter
Someone (not our poster, but Tone) probably did a little kung-fu with the door creating the large split, and probably that same someone, remorseful but no yet sobered up, tried to fix it by banging some nails to hold the split in place, without predrilling.
Old 01-25-2012, 06:24 PM   #14
dutchmans work extremely well, your basically removing wood that has failed and replacing with new. ive done it many times and its worked every time.. ive tried the clamp method 3 times twice it failed even with letting the glue cure overnight,
Old 01-26-2012, 03:32 AM   #15
Oh, that's easy to fix!
Separate it apart slightly with a putty knife very gently where it is cracked and scrape out gently any old and loose wood that is coming out. Then pour a bunch of liquidwood into the crack while its seperated. Then clamp it together slowly but not 100% tight .. just enough to hold it together and get it back equal with teh rest of the door. Then let it cure overnight.
http://www.youtube.com/watch?v=2yGQM...layer_embedded
Note: Liquid wood is basically epoxy so it will last a long time and be very strong.
For the hole where the hinge is. Just get a dowel that fits the hole size. Put a bunch of wood glue on the dowel and in the hole and tap it in, but not to hard or to far or it will crack again. You can then cut the excessive dowel off with a jap saw after its dried up. May need to sand it down flush if its not flush after cutting it off. I would do this though after the liquid wood is finished curing overnight.
http://www.woodcraft.com/Images/products/12F24_400.jpg
jasin is offline   Reply With Quote
