Re-staining Front Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 11:42 AM   #1
Rewards Points: 150
Re-staining front door
We are looking at cleaning up our front door. About 4 years ago we sanded and stained our front door. We paid our neighbor to put a uv protectant coat on top since he was also helping us to finish our basement. Its looking pretty rough and we need to clean it up before the HOA sees it.
This is not a real wood door. I believe its just has a thin layer on the front that acts/looks like wood. Last time we lightly sanded the door.
What should I use to remove the finish?
I plan on using a gel stain to change the color a bit.
What UV top coat should I put on? We get sun all day on the front of our house (great in winter as it melts the snow but harsh on our house) We do have an overhang so the middle and left side are pretty protected by rain. Rain can hit the one on the right side if it comes in at the right angle.
klmeenan is offline   Reply With Quote
Old 05-16-2011, 11:50 AM   #2
Rewards Points: 150
forgot the pics
Old 05-16-2011, 01:36 PM   #3
Rewards Points: 5,336
You'd use a chemical paste stripper to get the finish off.
A Marine poly would be my choice of a top coat. I'd use 2-3 coats.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
klmeenan (05-16-2011)
Old 05-16-2011, 03:05 PM   #4
Rewards Points: 150
Thanks! Would a regular paint store have Marine poly? I have never looked to see if SW has anything like that.
Old 05-16-2011, 04:05 PM   #5
They should. Minwax carries this product in their line.
Ron
Old 05-17-2011, 10:21 PM   #6
Rewards Points: 282
spar urethane.
it still needs to be redone every 3-4 years. sun is rough.
jcrack_corn is offline   Reply With Quote
Old 05-18-2011, 07:00 AM   #7
Is this, possibly, a fiberglass door? If so, be careful with the chemical stripper. Left on too long, it can damage the surface.
Unfortunately, chemical stripper may still be your best option. Just make sure you don't let it sit long. Also, I understand that denatured alcohol should be used to quickly wipe down after stripping.
I also had some luck simply applying a based coat of beige paint to a fiberglass door, then staining.
oberkc is offline   Reply With Quote
The Following User Says Thank You to oberkc For This Useful Post:
klmeenan (05-19-2011)
Old 05-20-2011, 04:58 PM   #8
www.doors4home.com
jason.r's Avatar
I agree with jcrack_corn. Spar Urethane is definitely the way to go. Marine poly will yellow over time. Regular maintenance is a must.
jason.r is offline   Reply With Quote
Old 05-20-2011, 05:23 PM   #9
Rewards Points: 150
Thanks Guys! I really appreciate all the info. I will pick up some spar urethane and get this done as soon as it stops raining.
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 07:00 AM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Front entry door repair ideas??? 4just1don Carpentry 2 01-26-2010 07:09 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
