Rangehood Install Undercabinet - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 10:53 PM   #1
Rangehood install undercabinet
Need help in fixing range hood under cabinet but unfortunately the place where to screw range hood to cabinets there are edges of cabinet so can't screw in any thoughts on how to fix?
karsat is offline   Reply With Quote
Old 09-17-2011, 06:34 AM   #2
Not sure I exactly understand what you mean, but having dealt with a couple of range hoods-
Most range hoods are flat on the top side, and are made to mount to a a flush flat surface. Above the stove, I suspect that there is a lip of cabinet edge across the front and two sides. This lip does not allow the range hood to sit flush against the bottom of the cabinets. Is this the "edge" you are describing? If so, you need to add some filler strips to the underside of the cabinet. Measure the depth of the recessed area, cut some wood scraps to the same thickness, and screw them in from the inside of the cabinet. That will present you with a flat surface, to which you can fasten the range hood.
If this is not your situation you may want to post some pictures.
ramcr913 is offline   Reply With Quote
Old 09-17-2011, 06:42 AM   #3
Yes its the same edge but filling the gap may not help as screws still need to be hinged on edges
Old 09-17-2011, 06:58 AM   #4
Rewards Points: 1,216
Whaat??
COLDIRON is offline   Reply With Quote
Old 09-17-2011, 07:25 AM   #5
Rewards Points: 5,336
Any reason you can't put the screws in another location? There's no rule you have to put the screws where the holes are, as long as the spacing is sufficient to hold the unit in place.
Ron
B. Franklin 1759
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
