-   -   Range hood venting (http://www.diychatroom.com/f14/range-hood-venting-46986/)
rdm440 06-18-2009 08:14 PM
Range hood venting
Installing venting for a new range hood over an electric range. The vent is hung where it has to go and calls for a 6" round vent pipe. Since I need to go thru the wall directly, I have a 90 degree elbow which conveniently is bisected by a 2 x 6 wall stud from 0 - 2" inside the vent. My options appear to be to cut the stud and scab it on the other side with a 2 x 4 or somehow get a 6 - 4 reducer to bypass the problem without cutting.
Suggestions?
Chemist1961 06-18-2009 09:03 PM
Do you have enough space to offset sideways with a 45 degree and then go through with your 90
Ron6519 06-18-2009 10:24 PM
You need to maintain the 6" duct all the way to the terminus. Cut the stud and box the space as you would installing an A/C.
Ron
toolbelt Tina 06-22-2009 10:50 PM
me too
Ron
I don't mean to hijack this thread but I am installing an over the range microwave.
I added a wet wall (2x4) to encase the plumbing so I can run the duct up there. What materials do you use to box the vent ? Thermopan sheets?
DOn't you worry about the greasy odor leaking out?
Which is better,wall or roof vent?
thanks Tina
adpanko 06-23-2009 06:15 AM
The best is whatever is shortest and has the least amount of turns. All else equal, I believe roof venting is better because hot air naturally rises, so you'd have that working for you. But so long as the run isn't far and you don't have many bends, either wall or roof will work just fine.
Ron6519 06-23-2009 08:21 AM
thanks Tina
I don't know what you mean by, "box the vent". your microwave probably will use the 3x 10" rectangular metal duct. Where you put the pieces together, you use metal tape to seal the joint. As stated before, the shorter the run, the better. The instructions will tell you the longest run allowed. Just realize it's not just linear feet they're talking about. Every bend is like adding 5 feet to the run due to the restrictive nature of a 90 degree turn.
Ron.
Mop in Hand 06-23-2009 10:02 AM
As Ron says reducing the vent is not recommened, it will make the fan not only work harder, and will cause the fan to be much louder. Go around it or cut the stud.
Mop in Hand 06-23-2009 10:19 AM
Toolbelt tina, do not box that vent in as you would with a cold air return duct. It is not allowed by code nor is it a good idea. Using anything other than a smooth metal interior is asking for a grease trap.
toolbelt Tina 06-24-2009 08:45 PM
Ron.
I was reading your earlier advice in the thread.
Ron
sorry if I misunderstood.
cheers Tina
toolbelt Tina 06-24-2009 08:57 PM
a few more ?s
That was my thinking that you needed a solid piece vent re the grease.
This a cottage. After cooking my first meal I turned on the fan over the stove. I noticed the fan wasn't pulling in the air. Opened the cupboard above to discover no vent. And the cabinets were second hand so there was a hole for a vent. Not even a charcoal filter.
Can I take the rectangular duct and convert it to a flexible round duct of the same diameter?
Do they sell pieces of preformed ducts (straight run) or do I have to form my own?
Sorry I don't venture down that aisle much @ Lowes.
Gary in WA 06-24-2009 09:26 PM
Lowes has a selection of ducting and fittings. You may need a transition: http://www.lowes.com/lowes/lkn?actio...12H&lpage=none
And a roof termination: http://www.lowes.com/lowes/lkn?actio...34M&lpage=none
And an elbow, some straight pipe that comes flat, and some foil tape for all joints (even elbow). It comes in a few diameters, depending on the hood manufacturer's recommendation. Support the pipe in the attic, and a few screws in the joints, little sheet metal self-starters.
Or buy the whole package: http://www.lowes.com/lowes/lkn?actio...377&lpage=none And maybe more straight pipe. Be safe, G
toolbelt Tina 06-24-2009 10:00 PM
thanks for the links
etc
thanks for the links GBAR. Can I use flexible round ducting?
Mop in Hand 06-24-2009 10:57 PM
Flexible ducting is not allowed, the interior must be smooth metal.
Chemist1961 06-25-2009 06:23 AM
Also 3 srews per joint (code) and seal with FOIL tape:thumbsup:
toolbelt Tina 06-25-2009 03:02 PM
thanks for the tip
thanks for the info Mop.
I was hoping to use a flex duct easier to work with. I'll get out the aviation snips then.
thanks Tina
