RamSet Issues - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 12:24 PM   #1
RamSet issues
Attaching treated 2X4 to basement floors using the single shot (hammer blow) ramset with 2 1/2" pins with washers, and the yellow #4 shot.
EVERY single shot leaves about a 1/2 of the pin up, never does it fire a flush shot.
Whole purpose of using the RAMSET is so I don't have to drive Masonry Nails, but I have to follow up with unwanted hammering on every shot.
Solutions??
itsbob is offline   Reply With Quote
Old 09-29-2011, 01:58 PM   #2
Rewards Points: 5,336
Solutions??
Move to a higher powered shot.
Ron
B. Franklin 1759
Old 09-29-2011, 02:03 PM   #3
I thought the Yellow #4s were the highest (.22 cal)?
Old 09-29-2011, 02:24 PM   #4
Rewards Points: 1,560
Go see:
http://www.ramset.com/loads_chart.asp
If not available, try shorter nail or get softer concrete.
bob22 is offline   Reply With Quote
Old 09-29-2011, 03:00 PM   #5
Originally Posted by bob22 View Post
Go see:
Yellow #4 is the highest load for the .22..
Just ordered a Remington 496 in .27 cal with Red(#5) and Purple (#6) loads
Amazon (suziq69) has the 496 for $110, 100 shots were about $8 from other suppliers.
Old 09-29-2011, 05:58 PM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Solutions??
is this the tool you are trying to drive a 2-1/2" pin with ?
Ramset 721
Maximum Pin Length: 1-1/2"
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-29-2011, 06:08 PM   #7
kwikfishron's Avatar
Rewards Points: 174
Shoot it again.
kwikfishron is online now   Reply With Quote
Old 09-29-2011, 06:10 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Old 09-30-2011, 08:04 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
as the others have stated, switch to a higher power shot. they come in 6 different levels. if that doesnt work rent a actual ramset as opposed to the hammer strike model. better grade guns have a dial which you can dial in the depth of setting the pin
woodworkbykirk is online now   Reply With Quote
Old 09-30-2011, 08:19 PM   #10
KemoSabe
loneframer's Avatar
Personally, I'd shoot a 2" pin. If it overdrives slightly, no biggie, but asking for 1" embedment in cured concrete is more than what is reasonable for the single shot hammer actuated model. Possibly even the 27 cal 10 shot pump.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 10-17-2011, 11:21 PM   #11
Originally Posted by kwikfishron
Shoot it again.
Didn't think I could but it worked. Overdrove the pin a little on the second shot but not enough to be concerned.
Old 10-17-2011, 11:23 PM   #12
Just had the .27 delivered and NO issues with the #5 load, in fact am sure I could go down to a 4 or even 3. Love the 10 shot clip.
Ramset alternative? McCool Tools 8 03-02-2011 06:04 PM
House settling issues gmvshort Building & Construction 3 02-22-2011 07:26 AM
Demo'd Half-Bath, Issues, Pics Attached, Have at it... 99altrade Building & Construction 4 12-21-2010 05:50 PM
Spray foam - code issues? upinsmoke Building & Construction 1 05-10-2010 08:47 PM
