Raising The Ceiling In The Living Room Of A Ranch - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-03-2014, 04:55 PM   #1
raising the ceiling in the living room of a ranch
My Father in Law wants to raise the ceiling in his living room to make "half" a cathedral ceiling. The back wall of the room is in the center of the house and that of course will be the high point of the ceiling. Besides sistering in some larger rafters in the cathedral area to allow for insulation and ventilation, are we going to have to put in a ridge beam and make that center wall a load bearing wall? Can I build on top of the center or do the studs need to be continuous? I'm worried about spread loading pushing the opposing wall outward.
barkerbob is offline   Reply With Quote
Old 02-03-2014, 06:28 PM   #2
Rewards Points: 13,300
Are there trusses or was it stick built?
Old 02-03-2014, 06:52 PM   #3
Taller ceilings look cool but there a pain in the butt to insulate, vent and just add more area that needs to be heated and cooled.
Old 02-03-2014, 08:59 PM   #4
Cathedral ceiling
It is stick built. He's thinking of doing a scissor trust. Or at least half of one. Is there any rule as to how far up I can go?
Old 02-11-2014, 11:37 AM   #5
Did this once but did a vaulted ceiling instead of cathedral. It really seemed to open up the living room and was still easy to insulate. Can't speak for cathedral, but I would think that enough attic bracing would suffice.
Queefer is offline   Reply With Quote
Old 02-12-2014, 07:01 PM   #6
Registered User
Rewards Points: 5,266
Either change to the structure will require a building permit, check with your local AHJ. HO Insurance claims denied, time at sale, etc.
Gary
Tags
spread load cathedral
Vaulted ceiling crown molding with adjacent room cmcfalls2 Carpentry 4 10-13-2011 11:38 AM
what is the best type of recessed light to have a bright living room scupit Interior Decorating 1 07-16-2011 11:37 PM
Ceiling is very hot in the living room 3caddydaddy Insulation 4 06-22-2011 03:55 PM
Is my room pre-wired for a ceiling fan? cfrederick02 Electrical 1 04-02-2009 02:08 PM
Living room colors-Yellow, White, Sage or Taupe Minak Painting 22 02-21-2007 03:31 AM
