Raising The Ceiling In Bedroom - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 02:35 PM   #1
raising the ceiling in bedroom
our project is a 10x10 bedroom in which we are wanting to raise the ceiling to the roof rafters thus making like a cathedral ceiling type thing, anyhow my question is do you drywall to the rafters that go then to the roof plywood or any need of insulation in that space? I have read alot on here and am confused. any help would be great. if this helps weigh your answer we live in Georgia so no we don't get snow , maybe a day or two nothing that piles up. Thank you to anyone who can help.
STACI is offline   Reply With Quote
Old 05-16-2011, 02:43 PM   #2
Framing Contractor
Rewards Points: 96
The ceiling joists that you plan to remove are very likely to be structural members. Check with an engineer before removing them. The rafters will probably need to be beefed up in order to remove the ceiling joists without causing the roof to sag. Only then should you be concerned with the insulation.
sixeightten is offline   Reply With Quote
Old 05-16-2011, 06:41 PM   #3
DIY staff
Rewards Points: 7,174
You definitely need an architect or engineer or draftsman to see what you have and design a plan for you to follow.
The ceiling joists hold the walls up---the roof rafters will collapse the walls if the ceiling joists are removed.
oh'mike is online now   Reply With Quote
raising ceiling on first floor highlandarx Building & Construction 18 06-08-2011 05:07 PM
Detached Garage, Raising Ceiling Rafters?[pics] alecmcmahon Building & Construction 13 05-30-2010 01:30 PM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Raising the ceiling MrTique Building & Construction 4 12-04-2007 11:06 AM
raising ceiling famtwp Building & Construction 10 05-30-2007 09:00 PM
