Railings Repair - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 10:03 AM   #1
Rewards Points: 24
railings repair
The top is made from a pressure treated lumber but it started to look horrible shortly after it was replaced.
https://picasaweb.google.com/1088643...CNj986OLg8amDw
How is this properly done?
Thank you!
ozdiy is offline   Reply With Quote
Old 06-10-2012, 10:26 AM   #2
Rewards Points: 1,294
There is another post on this same thing. The problem is the pressure treated wood you are using has shrunk as it dried out. This is a common problem. One way to overcon it is to use composite decking material. another material to use is the newer plastic wood facia material that is out. Comes in white and some other colors, as easy to work with as wood, but does not shrink, crack or check.
danpik is offline   Reply With Quote
Old 06-10-2012, 08:22 PM   #3
AHH, SPANS!!!
Rewards Points: 1,166
Thank you!
finding one of the composites that works with the color of your house paint color may be the best choice there, or caulk and paint the rail to cover the cracks and extend the life of the rail. you can also get the cpvc lumber, a 5/4 x 6 to replace that pressure treated 5/4 x6 and then paint it
hand drive is offline   Reply With Quote
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 09:55 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
