Railing Attachment - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-05-2012, 01:26 PM   #16
Bombastic Idiot
notmrjohn's Avatar
Don't look for a Stair rail hanger, with a fancy tightening system or even a hex shank. Just a hanger bolt, then do it the old timey way with fender washer, washer, and nut on end of bolt, possibly a jam nut too. Might mean a bigger access hole to get a wrench in there. Will mean a lot of short turns with wrench. When you plug the access hole use barely enough glue to hold it or hope for friction fit, easier to take out if you ever need to tighten it.
Don't know what kind of rosette you're using, but if solid center, drill hole to fit hanger, a dab of adhesive on back to prevent spin, when you tighten hanger it will be clamped against wall.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-05-2012, 01:34 PM   #17
Rewards Points: 109
I didn't, just asked for a hanger bolt, the longest they had was 4"
BimmerRacer is offline   Reply With Quote
Old 09-05-2012, 03:05 PM   #18
Bombastic Idiot
notmrjohn's Avatar
They're out there keep looking, whats your location? May have to above retail to suppliers or on line.
Old 09-05-2012, 03:07 PM   #19
Rewards Points: 109
Maryland outside DC. Yeah probably just going to order online
Old 09-06-2012, 06:15 PM   #20
Stairguy
Millertyme's Avatar
Rewards Points: 508
Screw the rosette into the rail from the backside of the rosette with deck screws. Screw rosette with rail into wall, one screw on top and one on bottom. Plug the two 3/8" holes with plugs taken from back of rosette.
Millertyme is offline   Reply With Quote
Old 09-06-2012, 07:17 PM   #21
Bombastic Idiot
notmrjohn's Avatar
I gotta back up. All we wanta do is fasten end of rail to wall, right? Why do you need such a long screw? You got 1/2 drywall with 2x framing behind it don't you? The 2x may even be turned broad side out so you only got 2" of grip anyway. Or did i miss something?
If Miller's rosette idea doesn't appeal to you, then go back to his drawing, get a lag screw of whatever length you want, put a washer, then a fender washer on it, screw it into wall depth so head goes into access hole, drop rail on it, tighten lag screw. Accurate pilot hole in wall and wax on screw will help. Now go do newel, which you are going to screw into from inside newel? Or did i miss something else?
Old 09-10-2012, 06:52 AM   #22
Rewards Points: 109
Done. Need to figure out what stain to use next, before setting the balusters.
I ended up using a few 18ga nails to secure the rosette to the wall and used 5" hanger bolts to drive into the framing. Made and plugged the holes as Millertyme suggested.
Inside the newels I used 3" lag bolts with a fender washer so nothing is visible from the outside there.
Thanks for the help all
The Following User Says Thank You to BimmerRacer For This Useful Post:
mae-ling (09-10-2012)
Old 09-10-2012, 09:37 AM   #23
Bombastic Idiot
notmrjohn's Avatar
Some close ups please, the rosette, etc. So where did you finally find your hanger bolts? I did a short search and found all kinds of them ,length and material wise, pretty good bargains...for a 100 bolt lot. Or buy one at a fair price and pay 12 buck shipping charge.
Old 09-10-2012, 09:57 AM   #24
Rewards Points: 109
I did the second option, from http://www.westfiremfg.com/. I chose them since all of the other supplies came from there.
I'll snap a few pics tonight when I get home.
Old 09-10-2012, 10:11 AM   #25
Bombastic Idiot
notmrjohn's Avatar
Well, whadda ya know. I searched hanger bolts, when should have searched stair parts and materials. Thanks for link.
Old 09-10-2012, 05:46 PM   #26
Rewards Points: 109
Here you go
Rosette was made out of newels leftovers. I used a little $30 jig i got from Amazon to drill the baluster holes to a 1" depth. Still have to sand it and get everything ready for clear.
Old 09-10-2012, 07:13 PM   #27
Bombastic Idiot
notmrjohn's Avatar
Sweet.
Old 09-11-2012, 11:11 AM   #28
Ole Wood Worker
BigJim's Avatar
Rewards Points: 804
Do you plan to leave the plowed rail filets out of your rail, I noticed that you have the rail drilled for round top spindles instead of square top spindles.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-11-2012, 11:33 AM   #29
Rewards Points: 109
Yes not using them
BigJim (09-11-2012)
Old 09-13-2012, 04:03 PM   #30
Stairguy
Millertyme's Avatar
Rewards Points: 508
You should have bought the proper rail without the fillet. It doesn't look professional like that. I would have glued in the fillet before drilling the holes.
The Following User Says Thank You to Millertyme For This Useful Post:
BigJim (09-14-2012)
Extending height of deck railing tntworks General DIY Discussions 4 03-11-2013 07:16 AM
Attaching porch railing to brick wiz561 Building & Construction 0 06-19-2011 01:39 PM
How/ What to do with the railing? Fantastic Building & Construction 2 02-22-2011 09:04 PM
Tile under or around a railing? RandyKlein Remodeling 3 06-13-2010 09:08 AM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 11:19 AM
