Railing Attachment - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 11:04 AM   #1
Rewards Points: 109
Railing attachment
I am looking for a way to attach a rail between a wall and box newel and between two box newels. I am not planning on using a rosette on a wall for cleaner appearance.
I initially thought I could just use rail bolts to attach to the wall and since i can get inside the box newel use the same hardware with a flat washer in there. But now, thinking about it more, I am not sure I can actually do that since both the wall and the rail are fixed and can't move? Does this make sense?
BimmerRacer is offline   Reply With Quote
Old 08-23-2012, 12:04 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 392
A picture would help us see what you are doing. As for attaching a rail to the wall without anything backing it is asking for problems, the sheet rock will not hold up without something to protect it where the rail attaches to the wall.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-23-2012, 03:52 PM   #3
Rewards Points: 109
Sure, although I am not seeing how a rosette will solve my issue.
Pics attached.
Old 08-23-2012, 05:14 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 392
I didn't use the rosettes when I was in business because I didn't like the look, if it were mine I would put a half post at the wall and fasten the rail to it.
Jim
Old 08-23-2012, 05:16 PM   #5
Rewards Points: 109
Half post won't work. The wall is too narrow for them
Old 08-23-2012, 07:24 PM   #6
Stairguy
Millertyme's Avatar
Rewards Points: 508
I would install the regular rail bolts in the post and one in the wall. Drill the 1" hole in the bottom of the rail for the rail bolt wrench like you normally would. I then cut a slot in the bottom of the rail so the rail can slide over the rail bolt on one side only. I usually just do this with a jigsaw. Attach rail as you normally would. Then you go back and fill in the slot. I usually make a small wedge shaped piece so it fits snug. Then I go back and fix the 1" hole with a dremel tool.
Millertyme is offline   Reply With Quote
Old 08-23-2012, 07:33 PM   #7
Stairguy
Millertyme's Avatar
Rewards Points: 508
How about a square rosette there with beveled edges?
Old 08-23-2012, 08:24 PM   #8
Rewards Points: 109
What do you mean by that last part?
Old 08-24-2012, 05:15 AM   #9
Stairguy
Millertyme's Avatar
Rewards Points: 508
Hope this helps
Old 09-05-2012, 09:36 AM   #10
Rewards Points: 109
So, back to this...for the rosette, any suggestion on how to attach it to the wall so that no screws/plugs are visible? Also, I don't think the rail bolt is long enough to go through the rosette and drywall to reach the framing. T
This is the handrail I am using
Old 09-05-2012, 10:09 AM   #11
Rewards Points: 2,212
If you use the rail bolt as suggested then only need to nail the rosette on.
I was able to get different lengths of bolts.
mae-ling is offline   Reply With Quote
Old 09-05-2012, 10:36 AM   #12
Rewards Points: 109
I don't think big box stores carry them in different lengths. Was hoping to do it this weekend
Old 09-05-2012, 11:23 AM   #13
Bombastic Idiot
notmrjohn's Avatar
How long do you need? Walk out of big box, go to Hardware store, hanger bolts up to 12". Farm and ranch supply even longer.
notmrjohn is offline   Reply With Quote
Old 09-05-2012, 12:56 PM   #14
Rewards Points: 109
I'll check my local Ace...I am thinking 5" would do. Thanks
Old 09-05-2012, 01:18 PM   #15
Rewards Points: 109
No luck at Ace
Extending height of deck railing tntworks General DIY Discussions 4 03-11-2013 07:16 AM
Attaching porch railing to brick wiz561 Building & Construction 0 06-19-2011 01:39 PM
How/ What to do with the railing? Fantastic Building & Construction 2 02-22-2011 09:04 PM
Tile under or around a railing? RandyKlein Remodeling 3 06-13-2010 09:08 AM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 11:19 AM
